Clean Headlights.
Clean Headlights.
always looking at my headlights they look quite foggy..
i was wondering if theres a way to polish them from the inside so they come up as new.,
and idiots guide would be nice.
Clean Headlights.
You can polish them with car polish and this works very well but do not over do it with a heavy cut. The polycarbonate lenses are coated at time of manufacture but they tend to deteriorate with time and weathering.
- philz
- Wheel guru
Clean Headlights.
mothers plastic polish
- Jeo
Clean Headlights.
philz wrote:mothers plastic polish
+1
- sliq
Clean Headlights.
on NB's, you'll have to rip off the front bar to clean the lights from the inside.
Clean Headlights.
You clean the lense from the outside. The lense is hot melt glued to the housing.
- 16bit
Clean Headlights.
going to give mine a go with micro fibre this weekend.
- irwin83r
Clean Headlights.
Jeo wrote:philz wrote:mothers plastic polish
+1
+2
on the outside
- PUR157
Clean Headlights.
Just make sure you don't jump straight to the most abrasive compound you have... I've read that it's best to work your way up to consecutively rougher compounds if you find the finer ones don't work... coz then you'd just spend the rest of the day polishing back the swirls
Oneness of Man and Machine
Clean Headlights.
sliq wrote:on NB's, you'll have to rip off the front bar to clean the lights from the inside.
is there a tutorial anywhere? coz im sure most of the grime is on the inside. but i cnt get to that anyway can i.
- sliq
Clean Headlights.
yakob wrote:sliq wrote:on NB's, you'll have to rip off the front bar to clean the lights from the inside.
from big forum
Clean Headlights.
Gents trust me- this is just a case of applying a light polish to a cloth rub on and rub off- apply again if not satisfied- but do not rip it into it- you do not want to completely remove the unseen hard coating on the lenses which provide long term life. I recently did this on badly weathered headlamp lenses on a Festy and the job was done in 5 minutes. It is the same process as polishing your paintwork. As an aside I have often seen taillight lenses buffed to remove marks in OE manufacture and it recovers otherwise reject parts. Too easy they say.
Clean Headlights.
Mr Morlock wrote:Gents trust me- this is just a case of applying a light polish to a cloth rub on and rub off- apply again if not satisfied- but do not rip it into it- you do not want to completely remove the unseen hard coating on the lenses which provide long term life. I recently did this on badly weathered headlamp lenses on a Festy and the job was done in 5 minutes. It is the same process as polishing your paintwork. As an aside I have often seen taillight lenses buffed to remove marks in OE manufacture and it recovers otherwise reject parts. Too easy they say.
i always just wash the headlights as i wash the rest of the car, soap and rinse. but i noticed that they seemed dull on the inside. can be fixed?
Users browsing this forum: No registered users and 224 guests
