Removing swirl using Meguiar Scratch X
- Garry
See how it looks after a couple of washes before you get to excited. You might find the swirls that you thought were gone will magicaly reappear.
- JBT
Garry has it in one. Check this for swirl and scratch removal
- apophis
- Vehicle: NB Roadster
Garry wrote:See how it looks after a couple of washes before you get to excited. You might find the swirls that you thought were gone will magicaly reappear.
3M cutting compound hey, might have to give it a go...
I am not afraid of your weapons, you know who the fk i am?
- ASE05
Polishing your car to get swirl marks out is like using wet n dry sandpaper. Start with a heavy cut compound and work your way back to a finishing polish. If you can remove a scratch with a cut comp. you'll need to work it back withy lighter polish to get the shine back.
You can get a good result and get lustre and shine with a quick polish but to get a premium result, multiply the effort X 5 at least.
Meguiar X is just a filler and the scratches will come back over time.
I'm a detailer and for an average job, I'll give the car 1 pass with a normal light polishing compound(1hr). Dark and red couloured cars require the extra effort to get a good result.
I recently did a black 2002 BMW M5 that had spent most of it's days going through touch carwashes. The paint was farked!!! 5hrs later and several hundred $$$ from the client had his car lookin' better than some brand spanka cars after the pre-delivery detail.....it only took 6 different grades of polish and 5 different pads and 16
passes and two passes with a wax. Some would say that much polishing would remove the clear coat altogether but that's not the case at all.
The biggest thing to remember with polish is let the polish do the work, avoid using too much pressure!!!!
- apophis
what cutting compound do you use?
- ASE05
It's all developed, produced and supplied by Cargroomers. I'm a franchise owner in Brissie
- apophis
yeah my blue is swirl city as well, I am going to try the cutting compound, you wont need to use too much force, let the product do its job.
I will let you know hey, I have stone chips, long scratches on bonnet and boot. Likewise its disgusting when you look at it closely.
