Too much Oversteer
adherent
Too much Oversteer
Postby adherent » Mon Sep 29, 2008 10:57 pm
I had a similar experience the first time in the wet with my mx5. I did these things in this order:
1. Dropped tyre pressure from 34 to 28 psi (free)
2. Got a decent alignment (Keith Tanners sport alignment) (about $60)
3. Dumped the crap tyres and got some decent tyres (off a forumite with half tread left, so cheap)
Each step along the way improved matters considerably. Do at least this much - doesn't have to be expensive.
Black 90 NA6 | LSD | Bridgestone Adrenalins RE0001 | HKS Pod Filter | 14BTDC
Adam_NAclubman
Too much Oversteer
Postby Adam_NAclubman » Tue Sep 30, 2008 2:28 am
bensale wrote:
Adam_NAclubman wrote:I wouldnt even bother with good tyres, rubbish tyres have less grip but are usually more progressive as the grip runs out.
Thats an interesting attitude.................. Surely you have some form of a death wish and place a lot of misguided trust in your fellow road users.
You can feel when crap tyres are running out of grip, sticky ones grip, grip, grip, nothing. I'd MUCH rather be able to feel what is going on than have to guess.
mx52nv
Purple Porsche Eater
Too much Oversteer
Postby mx52nv » Tue Sep 30, 2008 3:08 am
The point is that the OP wanted to correct his oversteer and mentioned that he had no name tyres.
Thus the obvious advice was to get good tyres, a good alignment and check all suspension components & tyre pressures.
This should reduce or eliminate oversteer tendencies.
Suffice to say, it is Adam_NAclubman's belief that with crappy tyres, you are able to "feel what is going on than have to guess" while "sticky ones grip, grip, grip, nothing".
However, this does not solve the oversteer problem of the OP.
For the sake of argument, I have sticky tyres.
On a day to day basis I would rather have "grip, grip, grip...nothing" than "slide, slide, slide...bang".
StanTheMan
Too much Oversteer
Postby StanTheMan » Tue Sep 30, 2008 9:04 am
I suppose if the tyres are different treads or rear ones are in better shape the tyres in better shape.
as long as the tyres are all the same. Grippy or not, it could make a difference.
each to thier own. I personally prefer sticky ones.
At least make sure all tyes are the same. Inconsistent tyres front to rear are no good.
Boags
Too much Oversteer
Postby Boags » Tue Sep 30, 2008 9:46 am
Adam_NAclubman wrote:You can feel when crap tyres are running out of grip, sticky ones grip, grip, grip, nothing. I'd MUCH rather be able to feel what is going on than have to guess.
IMO better tyres give you more/better feedback and let go more progressively than old/hard/cheap tyres. Even if you were to get grip, grip, grip, nothing; you are much better off than having no grip to start with.
You are usually pretty "on-the-ball" Adam; why do you have such a negative view of good rubber? Have you forked out the $$ for a good NEW set of tyres to compare the difference? It was hard for me to part with over $800 for a set of tyres for my NB, but I'm glad I did; the cheapies I had on my NA were just sh!thouse.
As for tyre pressures; I don't want to be anywhere near a driver with 28PSI in the tyres if you have to avoid a collision or brake heavily. Please go and put 36PSI in your tyres, it might not save you, but maybe your passenger, or another road user.
Boags
JBT
Too much Oversteer
Postby JBT » Tue Sep 30, 2008 10:01 am
Not in my experience.
Old tyres can let go viciously and unpredictably. Low quality tyres have less grip to start with and are generally less progressive at their limit than a quality tyre. Then there are wet conditions........ :shock:
bensale
Too much Oversteer
Postby bensale » Tue Sep 30, 2008 11:27 am
I still believe that it is very misguided to drive around using poor quality tyres, personally in an every day situation I would take the sticky tyres every time. Also consider the fact that tyres have a major impact on your braking distance, you could be running race brakes the size of a dinner plate, but they'll be no good if the only thing connecting them to the road are shitty old hard tyres. I would also like to see how your crap tyres cope in the wet, at least you'll be able to feel how little grip you have as you slide into a tree.
That being said I can understand your arguement to an extent. No doubt having less grip allows you to reach the limit earlier, push the car hard at lower speeds and in some circumstances have more fun. I'm thinking of older cars like MG TC's that were great fun to drive but had a top speed of 100kph. However with all the idiots out there I believe buying good tyres is a wise investment.
www.othersideproductions.com
GP
Too much Oversteer
Postby GP » Tue Sep 30, 2008 1:06 pm
:shock:
Graham
bensale
Too much Oversteer
Postby bensale » Tue Sep 30, 2008 1:16 pm
:shock:
If I can find them i'll post the statistics, tyre pressures make a massive difference to stopping distances, for street tyres and every day driving 36 psi is recomended.
Boags
Too much Oversteer
Postby Boags » Tue Sep 30, 2008 1:23 pm
bensale wrote:
:shock:
Please do post. I'm going off the advice of driver training instructors (I've done courses through several companies and they all say 36 minimum). 36 is minimum recommended for small cars; start going up from there with added weight. Your 4WD towing a boat/caravan should have 50+PSI in the tyres.
Please explain why you are so shocked, GP...
JBT
Too much Oversteer
Postby JBT » Tue Sep 30, 2008 1:30 pm
bensale wrote:....for street tyres and every day driving 36 psi is recomended.
Hot or cold?
bensale
Too much Oversteer
Postby bensale » Tue Sep 30, 2008 1:35 pm
Cold
bensale
Too much Oversteer
Postby bensale » Tue Sep 30, 2008 1:43 pm
The braking distances were in a book my Dad has, I'll see if I can find it.
I have anouther book that has some good stuff about pressures and aquaplaning.
A tyre with 1.5mm (legal minimum) of tread in 1.5 mm of water will aquaplane with a tyre pressure of...
16 psi at 67kph
24 psi at 82 kph
32 psi at 94 kph
36 psi at 105kph
Big differences...
JBT
Too much Oversteer
Postby JBT » Tue Sep 30, 2008 1:52 pm
Interestingly, I found >32psi cold in the old NA8 made it skittish over any road irregularities and ride like a dray. OTOH, the car's handling seemed much better at 30-32psi cold.....and the ride was more bearable.
The NC seems to work fine with 32-34psi cold on the street or the track.
GP
Too much Oversteer
Postby GP » Tue Sep 30, 2008 2:22 pm
Higher pressures = less grip normally.
How come Mazda recommend 26psi?
Graham
