Horrible squeaking on ignition
- Garry
Have you checked the tension on the alternator/power steering belts? That'd be where I'd start first.
- RawSouth
- Steampunk
Garry wrote:Have you checked the tension on the alternator/power steering belts? That'd be where I'd start first.
x2
- Garry
My money is on the alternator belt. You just need to loosen the locking bolt, turn the adjusting bolt a few turns to put a bit more tension on the belt and then retighten the locking bolt. Should take all of about 5 minutes. From memory you'll only need a 12mm spanner to do it and no need to get under the car. If it is the belt the longer you leave it the worse it gets as it will eventually polish the belt and it wont be able to transmit the power. The only way to fix it then is to replace the belt which is a lot more complex than tightening it up.
x2 on thrust bearing
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
- Locutus
solo22 wrote:the alternator was kicking in about 5 seconds after ignition to recharge battery
that doesn't sound right... i'm guessing you had the A/C on? there's a delay on the A/C after ignition.
