15x9's on a NB
oongie
15x9's on a NB
Postby oongie » Fri Sep 26, 2008 12:31 pm
Heya folks,
So I was procrastinating at work again and stumbled upon the 949 website, in my quest to get lighter and more responsive wheels.
according to the 949 website NO MODS are needed for the 15*9 6UL rims to fit a NB8B?
http://www.949racing.com/index.asp?Page ... ustom&ID=1
WTH? Really?
Is this claim really justified?
Any light shed much appreciated.
90 NA6 98RWKW of fury 1.7L fury box
Boags
15x9's on a NB
Postby Boags » Fri Sep 26, 2008 12:33 pm
Be careful; the US NB8B has NB8A brakes on it. You have to check if the rims will fit with the sports brake package (what we get standard).
I would have thought that width would have caused the biggest problem though.
Boags
16bit
Vehicle: NB8A - Supercharged
15x9's on a NB
Postby 16bit » Fri Sep 26, 2008 12:50 pm
also keep in mind that we generally don't get the same tyre range as they do in the states. they tend to put 275 35's on those. I would stick with 8's.
mx52nv
Purple Porsche Eater
15x9's on a NB
Postby mx52nv » Fri Sep 26, 2008 1:05 pm
949 Racing wrote:15x9 +36 13.4 lbs, 1.75" lip 6.375" backside setting - requires cutting fenders, flares and/or spacers on most cars.
Miata does not require cutting of sheet metal
I think the wording is ambiguous.
In the first sentence it clearly states that it requires cutting fenders, (adding) flares and/or spacers.
The second sentence then states that the Miata does not require cutting of sheet metal. Now this could mean it is unnecessary to remove the entire quarter panel (going to be hard for the rears) and cutting it.
Anyway, to answer your questions once and for all, here is a link to the thread by 949 Racing at CR explaining the difficulty in the fitment ->clicky
Basically, pulling/stretching/flares/camber/spacers and the "get creative, massage the car a little to solve clearance issues..." are all mentioned :mrgreen:
They will clear both Wilwood BBK and factory Sport brakes (what we got standard).
In short - you will be needing modifications to fit these wheels.
oongie
15x9's on a NB
Postby oongie » Fri Sep 26, 2008 2:10 pm
Cheers to all! Looks like some serious work needs to be done!
BWAH~ CBF~
though they only weigh little under 14 pounds...
Adam_NAclubman
15x9's on a NB
Postby Adam_NAclubman » Fri Sep 26, 2008 7:19 pm
DO IT!
You may need to roll the **** out of your guards, but you'll be able to say you're packing 9 inches :P
Charlie Brown
15x9's on a NB
Postby Charlie Brown » Mon Sep 29, 2008 10:01 am
Sure you can ‘do it’ but keep your bank balance topped up and a spare set of standard wheels in the garage to fit every time you are pulled over by Mr Plod and booked for running an illegal set of wheels.
I’ve said this numerous times, check with your States rules and regs on wheel modifications before you go to the expense of buying big wheels for your car.
In NSW you can only increase the width, diameter and track by 1” over standard.
And remember the more you increase the weight and overall diameter of your new wheels/tyres over standard the slower you will go.
Muzdaman
15x9's on a NB
Postby Muzdaman » Wed Oct 01, 2008 8:09 pm
Pick your tyre first then pick a wheel.
As per http://www.949racing.com/index.asp?Page ... ustom&ID=1
they will fit an NB but what tyres will you run?? The link has the tyres you can run but as mentioned some of the sizes are hard to get out here.
The first post in the link mx52nv added was done pre production and so isnt as accurate as the stuff on the website.
If you really want to go light look at 949's 7's and 8's. Wider tyres will weigh more too.
But the 9's look awesome.
Adam_NAclubman
15x9's on a NB
Postby Adam_NAclubman » Wed Oct 01, 2008 8:46 pm
If you want super-light wheels, tr and find a set of these Weds
Mine were 14x6 and weighed close to nothing, AWESOME to drive on
oongie
15x9's on a NB
Postby oongie » Wed Oct 01, 2008 9:42 pm
Oh gawd.. theres so much choice... really need to decide the look of the car moving forward...
Big fat wide wheels, or sporty light japanese wheels...
hrm... decisions decisions...
Adam_NAclubman
15x9's on a NB
Postby Adam_NAclubman » Thu Oct 02, 2008 1:55 pm
It'd be nicer to drive on the street with the light skinnies though... Stop/start driving is where you'll really notice the difference
949Racing
15x9's on a NB
Postby 949Racing » Fri Apr 17, 2009 5:16 pm
oongie wrote:Heya folks,
WTH? Really?
Old thread but I though I should chime in just the same. 225/45/15's on 15x9 6UL's clear the NB wheel openeing at full lock, full bump. All 6UL wheels clear OEM Sport Brakes. Check the 15x9 pics gallery to see what they look like. Same combo on an NA require a medium roll on the fornt and a slight roll in the rear. FWIW, 8's don't look bad at near stock ride height but the 9's look a bit goofy near stock height. Good idea to remove the liners on the NA with 9's as you are bound to want to lower it and will quickly use up a bunch more bump travel with the added ccompression force generated by the substantial increase in cornering grip.
American, but not fat
