OMX-596 - 1996 Spec'd NA6 - Updated 21 Apr 2013
Postby orx626 » Sun Aug 24, 2008 6:25 pm
AJ wrote:Kim got a great little video grab of you rearranging the line on Hungry Corner too danny :wink: :lol:
Haha, yeah I was just showing my wife some of the footage and that "pushing of the limit" came on! :oops: :lol: .
Would love to see the footage from outside the car. It was the second last lap of the third session.
AJ
Postby AJ » Sun Aug 24, 2008 6:29 pm
no worries, we're gunna edit out the boring bits (ie: waiting for you lot to come around again :P ) & make up a DVD to distribute around :mrgreen:
XMX5 Rogues
Postby orx626 » Mon Aug 25, 2008 11:29 pm
I went through the video footage tonight and extracted the lap times from each session....which was on par with what Fra66L was measuring with his GPS get up. :mrgreen:
Lakeside is 2.41km in length, so I calculated my average speed for each of the laps....and yes Lakeside is a very fast circuit indeed. :twisted:
I just missed an average lap speed of 130 km/h by 0.16 km/h on lap 4 of session 7, which was my best lap time of 66.82 sec.
Here's the vid....
Postby orx626 » Tue Sep 23, 2008 11:35 pm
Here's some vids from the Club Track Day festivities held at QR Willowbank yesterday.... :D
This shows what happens when you turn into turn 1 too early and consequently apex incorrectly....still kept the boot in of course! :twisted:
Rather than post up videos of each session I made up a couple of compilations of predominantly sideways action (slow) and the odd good line (slightly faster) :oops: :twisted:
Enjoy!!!...and turn your volume up!!! :twisted: :twisted: :twisted:
Postby orx626 » Sat Dec 27, 2008 9:35 pm
The next stage in the development of OMX-596 got underway today with the substitution of the NA8 5-speed with an NB8B 6-speed :twisted: . Accompanying the change-out was the replacement of the standard NA8 clutch flywheel assembly with a "lighter" NB6 item coupled with an Exedy Heavy-duty pressure plate and a standard organic sprung centre friction plate. The starter motor and its engine plate were also replaced with younger NB items (somewhat lighter than an NA item as well).
Here's the "kit" 8) .....after reading a few recommendations I'm going to try the Redline Lightweight Shock-proof Synthetic gear oil.
Close-up of the low km NB6 flywheel....
All the standard NA8 flywheel, clutch and 5-speed gearbox removed awaiting the newer bits...
NB 6-speed engine plate installed...plenty of mud from the last trackday underneath :x
NB6 flywheel installed...
New Exedy organic friction plate installed...
New Exedy heavy duty pressure plate installed...
NB8B 6-speed in place, but not torqued....enough for today, will finish it off and test drive tomorrow.
OMX-596 - 1996 Spec'd NA6 - Updated 28/12/2008
Postby orx626 » Sun Dec 28, 2008 10:09 pm
Finished the job off today :D .
Torqued the gearbox up...pain in the proverbial to get to a couple of the bolts :evil: ...fitted the tailshaft and filled the gearbox with lube.
The end result is nothing short of awesome :mrgreen: . Very, very happy with the improvement in performance. 5th is the new 4th!!!
The next stage should be underway in the next few weeks...pending work of course 8) .
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Dec 29, 2008 9:40 am
nice work mate how was the header clearance with the new box? I have heard that its not a direct fit for some headers (mine in particular - loch)
Postby orx626 » Mon Dec 29, 2008 9:51 am
16bit wrote:nice work mate how was the header clearance with the new box? I have heard that its not a direct fit for some headers (mine in particular - loch)
Hi James, there was no issue with header to box clearance. Headers need to be removed to remove and refit gearbox...doesn't matter whether its a 5 or 6 speed unit.
Postby orx626 » Mon Dec 29, 2008 12:03 pm
CONTI wrote:Danny
I spy a cad plated bracket, I may have missed some thing, but it looks like you are getting ready for some positive displacement fun!
Andrew
Hi there Andrew, well that didn't take long :lol: ....the bait (bracket) was there...well spotted :P . Positive displacement fun indeed 8) .
Postby 93_Clubman » Sun Jan 04, 2009 11:06 pm
Very nice Danny - sounds like a job for the M45...
Postby Okibi » Mon Jan 05, 2009 12:31 am
Nice work, wish I had a hoist :mrgreen:
Postby Hammer » Mon Jan 05, 2009 1:06 am
Okibi wrote:Nice work, wish I had a hoist :mrgreen:
I wish I had the know-how :mrgreen:
Postby orx626 » Mon Jan 05, 2009 11:16 pm
93_Clubman wrote:Very nice Danny - sounds like a job for the M45...
Indeed! :twisted:
OMX-596 - 1996 Spec'd NA6 - Updated 24 Jan 2008
Postby orx626 » Sat Jan 24, 2009 11:07 pm
Well the JR M45, Megsquirt PNP, Innovate LC-1, KnocksenseMS and ARE radiator install got underway today in extreme climatic conditions...those of you from Brisbane will know what I mean. :shock:
With the MS I'm ditching the factory AFM and going with the MS MAP and air temp sensors. For ease I positioned the air temp sensor in the dummy throttle body.
Hole drilled for the tapped boss to be welded in.
Tapped boss in position.
Engine bay prior to diassembly...
Removal of the radiator...
Removal of the throttle body...
Installation of the dummy throttle body and replacement of the aluminium pulley with the original item to ensure that the supercharger is dríven at the required speed. If anyone wants the aluminium pulley just PM me...$30 plus postage.
Installation of the belt tensioner assembly...this is another unit...not the standard JR offering...it replaces the standard power steering tensioner assembly.
This is the extension loom for the throttle position sensor...as the throttle body is relocated upstream of the supercharger.
The throttle body mounted on the supercharger.
As far as the mechanical installation is concerned, there is not a whole lot left to do....however I do need to make a heat shield of some description to go between the supercharger and the extractors. I continued on and completed the mechanical install just to be sure I had everything. Here is what it looks like. The factory AFM is only there as an adaptor to get the engine going...will need to make a tube to replace it.
As you can see I haven't attacked much of the electrical work....that is what the remainder of the Australia Day long weekend is for. :mrgreen:
Obviously the radiator has to go back in as well...this will be the first job of the morning.
ps. I hope tomorrow is not 33 deg with a humidity of over 90% :x
OMX-596 - 1996 Spec'd NA6 - Updated 24 Jan 2009
Postby Okibi » Sun Jan 25, 2009 4:56 am
Please please put some sorta intercooler on her and an upgraded radiator.
Since you have teh mad skillz how about a part radiator part cooler (for water/air cooling) to replace that poo brown radiator?
