I've had a hunt around but can't seem to find the info I'm after. I nned to remove the rubber trim on the outside of the door under the drivers side window to do a minor repair. I don't want to wreck all the clips etc trying to do this. Also does the quarter window have to come out first?
Can someone please give me a few pointers on the procedure to get this seal off.
Thanks in davance
Removing seal on door under window ???????
- emexv
Mark
Mark
- Alex
I remember Babs (who has since moved on) had a thread around here somewhere showing removal and replacement of this on an NA
Edit: Found it
viewtopic.php?f=28&t=28153
Edit: Found it
- TieNN89
emexv wrote:I've had a hunt around but can't seem to find the info I'm after. I nned to remove the rubber trim on the outside of the door under the drivers side window to do a minor repair. I don't want to wreck all the clips etc trying to do this. Also does the quarter window have to come out first?
Thanks in davance
if your gona remove it buy a new one to replace it
its not easy to remove
once the strip is bent good luck making it sit back nice and neat
there approx $60 each at the spare parts counter
Users browsing this forum: No registered users and 53 guests
