Hey guys,
I want to hook up a shift light in my '94 NA8 race car. Can someone tell me which is the RPM pinout on the ECU?
Thanks, Paul.
RPM - Which ecu pinout?
- SKYHI
- zoomzoom
- Vehicle: NA6 - Turbo
I just hooked mine up to the wire going into the taco itself since thats closer to where the shift light was going to be put anyways. I can't remember which one it was but I found it jsut by following thw wires from the cas and finding which coloured one matched one of the wires going into the cluster.
Tim
Tim
- SKYHI
Thanks, that might work.
I might see if I can track down a wiring diagram for the NA8 somewhere.
Paul.
Paul.
- corners
- Vehicle: ND - Supercharged
TCR wrote:Thanks, that might work.
Paul.
If you have no luck I can try and look in my manual at home.
- SKYHI
I found this site which seems to have a heap of MX5 wiring diagrams.
http://www.madracki.com/miata/wiring.html
According to this, the wire that comes from the coil to the tach on the '94 model is black/white.
Paul.
Paul.
- Caffeine
Or use the 'IG' pin in your diagnostics box under the bonnet, it's a 5V PWM signal with pulse width proportional to RPM
- Hellmun
- Vehicle: NB8B - Turbo
I just used the attached pdf document to draw it from the instrument panel.
BUMP.
Just a quick question - thought I'd use the serach function!
Did these methods work with everyone ok?
viewtopic.php?f=73&t=62834
Well,
just a heads up - got mine fitted today, and the pdf that Hellmun posted was a great help
Users browsing this forum: No registered users and 163 guests
