Bright Blue LED Light on RHS of Dash
Please be nice to me as I am new here.
Only had my May 2000 MX5 for a week (my first MX5).
I have a Blue LED light on all the time whether running or not. It is on the dash near the drivers side door.
Could someone please advise what it is for & should it be on all the time or not?
Thanks.
Thanks.
- Garry
It's not a factory fitted part so it could be anything. You might need to trace the wires back to see where they go to.
- sliq
any photos?
i only found out yesterday from Boyracer that my car had some alarm function for the boot you learn something new everyday..
welcome to the forum classicred
- TieNN89
Welcome to the forums
Any pics of this led?
Which part of Brizzie are you from?
- bensale
Possibly it is there to make people think your car has an alarm?
www.othersideproductions.com
It almost looks to me to be usual position for the fog lamp switch?
- TieNN89
That second picture there is a trigger switch for an alarm most likely
If you want I can come around and have a close look at it for you
- Jeo
My NA had a random red LED there that had something to do with the old alarm. It would flash about every 5 seconds or so when the alarm was armed.
- TieNN89
Jeo wrote:My NA had a random red LED there that had something to do with the old alarm. It would flash about every 5 seconds or so when the alarm was armed.
yup that would be the alarm its there to let everyone know your car is armed should turn off when the car is on so it doesn't annoy you
but from what I can understand 2000ClassicRed is always on
- Alex
Looks like a dealer installed alarm to me, I have one and it uses the same switch for the boot (but mine doesn't damage the paint as there is a protective "spot" where it contacts) and the blue light is in the same position as the red one I have.
- Hammer
Is there actually a switch for the fog lights on where that light is fitted?
On the NB8B the area is for the fog light switch.
Is a May 2000 a NB8B or 8A? Anyone?
- marcusus
I vote alarm too. My first '5 had a red LED in the same position as the alarm notification.
I'm fairly sure a 2000 is a NB8A too, hence no fog lights unless it had the fog light option (quite rare I think).
Definitely an alarm of some sort. Have also found another switch the same under the bonnet and a micro switch near the bonnet release. Most likely installed in South Australia (where car was purchased new). I would say owner #2 disconnected it for some reason. Need to find someone who knows about this type of alarm in Brisbane so I can have it reconnected/repaired. The bright blue light on my NB8A still annoys me.
Probably most of the alarm is not there- some get disconnected because they malfunction. The light has to be simple to disconnect- one snip and its gone.
Users browsing this forum: No registered users and 124 guests
