Short Shifter
Steampunk
Short Shifter
Postby Steampunk » Wed Sep 03, 2008 10:02 am
Benn, Boags and I have set up group buys for "generic" short shifters that are a direct copy of the Mazdaspeed design.
Even though they are $75 instead of $200+, they still work great.
The best I have tried is Novice1 one, which is from IL Motorsport. Expensive, but you get what you pay for.
That plastic cup will wear our over time, but I think you will get well over 100,000 before it starts to fail. I replaced mine with the OEM one and its still good.
TieNN89
Short Shifter
Postby TieNN89 » Thu Sep 04, 2008 11:28 pm
1red5 wrote:The best I have tried is Novice1 one, which is from IL Motorsport. Expensive, but you get what you pay for.
How do you know its IL Motorsports
I'm pretty sure hes not 100% sure if it is
Steampunk
Short Shifter
Postby Steampunk » Fri Sep 05, 2008 9:24 am
And I am pretty sure that your posts sure is confusing
Short Shifter
Postby sliq » Fri Sep 05, 2008 10:02 am
will the brass bearing fit on that short shifter?
Short Shifter
Postby bruce » Fri Sep 05, 2008 10:34 am
AZNTieN wrote:How do you know its IL Motorsports
I'm 100% sure I don't know what you're talking about. Ya sure?
TieNN89
Short Shifter
Postby TieNN89 » Fri Sep 05, 2008 10:06 pm
result of a hard days of working at work *cough cough*
How do you know its an IL Motorsports
I'm pretty sure Novice1 isn't 100% sure its an IL Motorsports
TieNN89
Short Shifter
Postby TieNN89 » Fri Sep 05, 2008 10:08 pm
sliq wrote:will the brass bearing fit on that short shifter?
it should cause its a replacement of the plastic one which with the IL Motorsports you use the one which was originally on your stock shifter
I'm not sure how to remove it so don't ask
I made sure i ordered myself a new one of them because its not expensive at all
Short Shifter
Postby sliq » Sat Sep 06, 2008 11:41 am
http://www.miata.net/garage/shortshifter/index.html
that's the install with photos. enjoy!
Steampunk
Short Shifter
Postby Steampunk » Sat Sep 06, 2008 5:14 pm
Apparently there are 2 sizes of bushings. Someone mentioned it, I think bigdog, in Caffeine's original GB thread.
Keith
Short Shifter
Postby Keith » Sat Sep 06, 2008 5:24 pm
Does anyone have any views on the ones they advertise on e-bay for $100 buy it now?
O6 Marble white NC ;91 Malibu Gold NA 1800 BP4W;1990 BRG LE hardtop, unmolested, original; 1993 Brilliant Black hardtop, unmolested, restored.
marcusus
Short Shifter
Postby marcusus » Sat Sep 06, 2008 6:41 pm
Right, just put my IL motorsports one in today. Works a real treat. Is a tad stiff, but I don't have any gear problems other than the general increased stiffness. Throw wise, it's ridiculously short now, which is great. I'm using the factory knob, but if I had something heavier like a skunk (which I also tried on the lever), it'd be a lot easier to change gears. Although the shift wouldn't be quite as short.
I do have one question for those of you who also have an IL short shift. Did you manage to get the last big metal ring on? I'm talking about the one that is essentially two cylinders, with one radius being larger than the other. How did you guys fit this? I found that if I used it, air would come through the gap since the ring didn't seal over the lever properly (the boots would spring it back off the lever). In the end, the solution I used was to stretch the upper boot over the gear lever boot and cable tie around that to hold them together to prevent the air coming through. I'd much prefer to use the metal ring though if someone knows how to fit it without it sliding out of position.
oongie
Short Shifter
Postby oongie » Fri Sep 12, 2008 1:29 pm
Theres a black nylon ring with a "spring like" thing on it that you need to pry out of the shift well/tunnel/hole.
With that ring out the finish should be flush.
90 NA6 98RWKW of fury 1.7L fury box
marcusus
Short Shifter
Postby marcusus » Fri Sep 12, 2008 6:51 pm
oongie wrote:Theres a black nylon ring with a "spring like" thing on it that you need to pry out of the shift well/tunnel/hole.
I pried that out when I did it. Managed to work that one out from the pictures with a little help from babelfish. I'm talking about this ring:
It's upside down in the picture so I could demonstrate which part it was exactly. I'm aware it's supposed to go on the other way.
I'm tempted to try putting it on over the weekend. At the moment, with the bit boot sitting over the little boot, I'm getting a slight rush of air through the rubber somewhere. Maybe the metal being there will stop it without causing any rattles.
Mick93
Short Shifter
Postby Mick93 » Sat Sep 13, 2008 9:00 am
I have a IL one on my 6sp and it is excellent. If you wanted a short, short shift kit I would recommend it highly.
Users browsing this forum: Google [Bot] and 7 guests
