beeper
nick viner
beeper
Postby nick viner » Sun Aug 31, 2008 5:47 pm
Hi Guys .
Someone here said it was easy fix to shut the door beeper up and it is located under the steering column. Buggered if I can locate it.
Does anyone have a definitve answer as to EXACTLY where it is? The noise is driving me nuts. It's a 2002 nb by the way.
Cheers Nick
Alex
beeper
Postby Alex » Sun Aug 31, 2008 11:02 pm
I'm not sure where the beeper is but I just unpluged a 2 wire connector under the steering column and that worked for me, if I do it for Andrew then I'll take some pics for you.
It requires removal of the panel under the steering wheel/column
Garry
beeper
Postby Garry » Mon Sep 01, 2008 9:35 am
What Akex said. Find the ignition key barrell. It will have to thin wires coming out of it. (Not the thick main wires at the back of the barrell) Follow the 2 thin wires to a 2 pin plug near the steering column and disconnect the plug. Silence and bliss. :mrgreen:
TieNN89
beeper
Postby TieNN89 » Mon Sep 01, 2008 6:26 pm
yep what they said
the beep in my nb8a is inside the instrument I'm pretty sure
nick viner
beeper
Postby nick viner » Mon Sep 01, 2008 8:12 pm
Thanks Garry I will try that.
The first wire (plug ) I pulled was the two wire job attached to the steering column .... no dice.
beeper
Postby Okibi » Mon Sep 01, 2008 8:37 pm
learn to respect the beep, it's there to tell you that you're doing something wrong. :mrgreen:
MXcrazy
beeper
Postby MXcrazy » Mon Sep 01, 2008 8:54 pm
In my NB8A, it was a White 2 wire connector under the steering column . All you have to do is disconnect it..
Previous Ride:2000 Evo gold NB8A
Current Ride: 2007 Honda CBR600RR
beeper
Postby Mr Morlock » Mon Sep 01, 2008 9:03 pm
It is surprising Okibi what annoys people- it seems to stop when the door is closed.
beeper
Postby sliq » Mon Sep 01, 2008 10:10 pm
why don't you just flick the key to "ACC" and it'll stop the beeping.................
Garry
beeper
Postby Garry » Tue Sep 02, 2008 9:57 am
The only way to stop the incesant beeping in my car was to remove the key from the barrel. Which makes it pretty hard to listen to the radio when cleaning or working on the car with the door open.
beeper
Postby sliq » Tue Sep 02, 2008 11:14 am
if i switched my key to ACCC, the beeping would stop.. but the "key in door" buzz still remains, not the 'beeping'
Garry
beeper
Postby Garry » Tue Sep 02, 2008 1:19 pm
Oh, I thought we were talking about the buzzing. What is the beeping for? To tell you the door is open? I'm not sure my car did that.
beeper
Postby sliq » Tue Sep 02, 2008 2:41 pm
the difference was:
1. When your key is rotated on the first click, only the electrics in the radio activates, and there is a beeping sound when you open your door..
2. When your key is rotated on the second click, ("ACC" mode), there are six beeps (on the NB8B's) when your seatbelt isn't slotted. The oil gauge and temperature gauge are also operated, so is your odometer.....
3. If your parker lights are switched on and the door is open, there is a buzz...
Garry
beeper
Postby Garry » Tue Sep 02, 2008 3:05 pm
Ah IC. I have number 1 deactivated on my car.
Juffa
beeper
Postby Juffa » Tue Sep 02, 2008 5:09 pm
Ah, the trials and tribulations of the modern MX-5. I prefer my plain and simple NA.....where the only buzzing and beeping eminates from the driver at high speed (over 80Kmh). :mrgreen:
J
