Brake Hydraulic Leak
Noodle
Postby Noodle » Sat Aug 30, 2008 12:48 am
There's currently a hydraulic leak in my braking system.
Just before I try to investigate where it's leaking, are there any common places that MX5's braking systems leak ? I have a NA8 if that makes a difference.
Thanks in advance.
Noodle
Postby Noodle » Sat Aug 30, 2008 2:21 pm
Ok... I have found the leak.
It seems to be leaking from my rear brake calipers, out of the piston wind back allen key bolt. Is there a seal there that I can replace? Or do I need to buy entire new calipers?
Keep in mind I am not refering to the piston caliper seals in the brake pad side.
Your help is greatly appreciated.
Postby manga_blue » Sat Aug 30, 2008 3:10 pm
The rear caliper seal and boot set includes an O-ring that goes around that allen keyed bolt. It could be that. It's not listed separately in a Mazda parts catalogue, but it just looks like an O-ring. Check out part 3, which is part of the 26-46Z kit for an NA8.
In any case, given that there's a leak of some sort in one caliper, I'd personally replace all seals in both calipers on that axle at least (and more likely all 4 calipers), and also consider re-honing bores and replacing pistons if they don't look perfect. Any leak is a sign of danger. James sells replacement kits from mx5centre.com.au
Noodle
Postby Noodle » Sat Aug 30, 2008 5:48 pm
Thanks for the reply
Was exactly what I was after !
Out of curiousity... where did you get that image from?
Do you have access to a Mazda parts no. catalog?
Postby manga_blue » Sat Aug 30, 2008 10:13 pm
Users browsing this forum: No registered users and 167 guests
