RE001 review
bensale
RE001 review
Postby bensale » Tue Aug 19, 2008 7:27 pm
Alex wrote:but once you go so far with the pressures you will have trouble with even tyre wear
You are more likely to increase wear due to a lack of pressure. I believe that anything up to 48psi on most tyres is safe and wont result in increased wear in the centre of the tyre.
I have my turanza's @ 40psi at the moment, it feels a touch too high. I found 38psi front 36 rear to felt the best. And I am wearing the shoulders slightly more than the centres, but I think this is due to the alignment specs.
www.othersideproductions.com
Caffeine
RE001 review
Postby Caffeine » Thu Aug 21, 2008 2:17 pm
Close to 10000km on these tyres now, they feel great!
Lots of grip, and when they do let get, it's very smooth and predictable, more so than any other tyre I've every dríven on 8)
Wet grip is great too.
I have a nail in the right rear, but it's not losing pressure so I'll keep an eye on it and get it fixed if it causes any problems.
Craig
RE001 review
Postby Craig » Thu Aug 21, 2008 3:06 pm
Caffeine wrote:Lots of grip, and when they do let get, it's very smooth and predictable, more so than any other tyre I've every dríven on 8) Wet grip is great too.
Yes I'm quite impressed with mine too, for all the same reasons! 8)
Caffeine
RE001 review
Postby Caffeine » Fri Oct 30, 2009 11:57 am
Well, I replaced the RE001's with another set of RE001's (still made in Japan)
They lasted just on 50000km, which is very acceptable. They weren't even down to the wear markers but were getting a bit skatey in the wet. Dry grip was still very good.
Second set cost me $218 a corner, no free radios this time either :(
Worst part is I haven't dríven on the new tyres yet, I managed to tear 5 ligaments in my clutch foot, and as such won't be able to drive for 4 to 6 weeks!
RE001 review
Postby sliq » Fri Oct 30, 2009 12:10 pm
was that mostly highway driving caff?
Caffeine
RE001 review
Postby Caffeine » Sat Oct 31, 2009 10:27 am
sliq wrote:was that mostly highway driving caff?
Mostly commuting to & from work. Not much country / highway except 1 trip to broken hill
lo0se3r
RE001 review
Postby lo0se3r » Wed Nov 18, 2009 11:01 pm
where do you find re001 that is made from japan?
I am looking for 14', cheap wheels FTW!!! =P
broady
RE001 review
Postby broady » Wed Nov 18, 2009 11:22 pm
lo0se3r wrote:where do you find re001 that is made from japan?
you won't find japanese 14" RE001 in australia.
http://www.bridgestone.com.au/tyres/tre ... nalin.aspx
click "sizes for this pattern" -- it tells you if they're made in australia.
人馬一体 NA8
6/5/2010
lo0se3r
RE001 review
Postby lo0se3r » Fri Nov 20, 2009 9:48 am
yeah, broady, but i heard that they area closing down the bridgestone plant in australia.
So, correct me if i am wrong, bridgestone tyre will come from japan.
if not, how do you find japanese made re001?
Any shops sells it?
Users browsing this forum: Google [Bot] and 117 guests
