Different rubber size fronts vs back??
here is a not so great diagram showing contact patches for wide and skinny tyres. this is just a generic diagram off the net, but it illustrates my point. remembering that our cars are light so they don't put much weight / downforce on the tyre as you can see, the SHAPE of the contact patch will change (from rectangular to square) , but the SIZE pretty much remains the same. therefore, due to the lightness of our cars big fat tyres do not guarantee more grip. i'd argue that there are more negatives than positives in going to bigger tyres. if you had a big heavy car squashing those fat tyres down , sure you'd get a bigger contact patch and it would be worthwhile.
So does that mean that the shape of the contact patch is more important than the actual amount of rubber on the road?
I'm so confused....a wider tire must add more grip somehow, otherwise, everyone would use 185's. Look at Porsche, Audi, BMW, all their performance cars use tires from 245's to 285's.
Hahaha, yeah, im confused
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
no, the shape is not as important as the size. you are just hung up on the notion that wider must be better.
yes all those cars you mentioned use wide rubber but i bet those cars weigh a lot more than an mx5.
wider rubber does have other advantages tho, slip angles and what not, but that is above my level of knowledge.
Haha, fair enough.....in your opinion is it better or worse to run a wider tire on the MX5?
A wide, thin contact patch would probably be better for lateral forces?
- Damo
A wider tyre has more rubber so you could use a softer compound without the tyre overheating more quickly. Seeing as these tyres will be intended for heavier/more powerful cars they will most likely use the same compounds so you won't likely see the benefits. That's my theory - sound logical?
NB8A (2000 Highlight Silver), KU36, Kaaz LSD, QFM A1RM, Mazda Competition engine/differential mounts, Town & Country cat-back.
- Gazbo
Have a read here http://www.carbibles.com/tyre_bible_pg2.html re:contact patch area (half way down page)
- Hellmun
- Vehicle: NB8B - Turbo
As I understand it more rubber gives you a larger heatsink. Remember Race tyres especially need to be kept in a certain heat band to be at their best grip (compound dependant). The heavier the car and the more heat generated the larger the heatsink. I believe as someone else has already ascerted that a contact patch wider than it is tall will produce more lateral grip at the expense of Braking/Acceleration as well. I know I spend more time at the limit of lateral grip then I do braking and especially accelerating.
I'm keen to try some 225/50/15 semi-slicks as I've been seeing over 90C in my semislicks after half a lap cooldown which seems to be past their comfortable range.
- irwin83r
semi slick tyres having a stiff side wall allows you to run a lower pressure, which increases contact patch, while maintaing side wall stiffness, as apose to a soft side wall which will bulge, become laggy in response to movements between the tyre contact patch and wheel angle and increase tyre tempratures due to an increase in rolling resistance and more so tyre flex. this being the case the contact patch is increased but it cant get any bigger side ways as the side walls do not spread out onto the road. there fore the contact patch grows forwads and backwards becoming more of a square then standard. surely there fore to get back to the standard contact patch shape you have to increase the width of the tyre. how much is way too much math then what im prepaired todo. this compinded with the want of a more rectangular patch then standard would make me want to run wider tyres.
but as helmund has pointed out with a lower tyre pressure the tyres work harder, through the side walls resisting flex, and the extra resistance to rolling created by the slightly flat tyre there fore the tempratures created in the tyre are increased and the tyre temp comes into play. this again as pointed out by helmund is dulled by having more rubber to desperse the heat but its really a balancing act to stay in the heat range of the tyre and mantaining a good foot print.
also worth noting if the sidewall of the tyre is a supporting member ie the tyre pressure is not high enough to support the cars downward force alone the side wall stiffness will be supporting some of the mass of the car this, and the resistance to opposite forces between the wheel and the tyre contact patch from cornering or accelarating/braking is the flex i am refering too creating more heat in the tyre.
matt9111 wrote:So does that mean that the shape of the contact patch is more important than the actual amount of rubber on the road?
Yes... but the tyres in question are usually on 18-20 inch diameter wheels. Meaning the tyre circumference is much larger than the 205/45x16 found on an NB8B. This has a major affect on the contact patch as well.
205/45R16 is common sized tyre on warm/hot hatches of the weight of a NB8b. So it is probably the best compromise for grip/comfort etc.
- 16bit
according to the good people at 949 racing you should go wider. For 15's on an 8 inch rim they reccomend 225 45 15's. The wider the tyre the greater load it can take, the less pressure you need which = more grip. having a wider tyre on the same size rim is always going to result in more contact patch. If you are serious about doing it email the guys at 949racing.com and see what he says. I would try and get the opinion of someone who has done it and tested it on the track.
track and street is a very different situation tho. what works for one may not work for the other. i assume wun is talking mainly about street.
the rules of physics don't change, but what we require from the tyre does change.
i think we have established that a wider tyre will give more lateral grip in extreme cornering loads as seen on the racetrack. i doubt many of us will ever experience such loads on the street. whereas a skinnier tyre should be more comfortable and have better grip in most other street situations (and in the wet?). everything is a compromise when it comes to suspension / tyres, but in general i reckon wider tyres, more suited to track use, skinnier tyres, more suited to road use. that's how i view it anyway.
