Does this sound to wide a wheel on an NB8b?
How does 17x8 at a 35 offset sound?
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
Too big in diameter, not low enough offset
Im turbo charging it later on, would the diameter still be to big? How low should the offset be?
Can you put such a wide rim on a NB?
Not sure
they will fit no problems. use a 215/40/17 or 205/40/17 and wont have any rubbing issues.
Are you looking at the gmax 'drift6' wheel. 17x8+35 4x100 + 4x114.3 multistud?
I need a sponsor
You can put a 8 +0 on a NB from what I've seen
As mentioned above you can run a lower offset, but you may have to run smaller tires and/or flare your guards.
What wheel/tire combo are you looking at?
marvis.
marvis.
I was looking at buying the Enkie RS+M wheels, but i lost the website I was on yesterday, and now all the websites I look up have different spec's on the wheels......interesting.
I have a crazy idea, maybe someone has done it before, I love the way the standard wheels look, do you think it'd be easy to get them custom made in a bigger size?
- AB7
That should fit as long you don't use really wide rubber, 215 probably the max.
I have 16 X 7 +25, so with 8" wide +35, it should be very similar. I didn't even have to roll the guard and they sit flush to the guards.
- sliq
AB7 wrote:That should fit as long you don't use really wide rubber, 215 probably the max.
darn these ce28n people.. jks
8 +0 on NB without ruined guards
I meant can you LEGALLY fit them to your car?
Hell no. But they fit
Users browsing this forum: No registered users and 203 guests
