I started rolling my guards to fit my new wheels yesterday, the SSR Mk2's I bought from ES86. Rolled and pumped the front drivers side, then went to test fit a wheel... Not enough clearance for my brakes, I'm sure they fited fine on his NA6 but they don't on my NA8
So because the back of the spokes don't have a bowl machined/cast into them to clear wider calipers, I need to either run spacers or get them machined. Problem is, I'm not too keen on either solution. Spacers will just pus them even further out into the guards, though I think I'd only need about a 5mm slip-on, and I don't know if taking more metal out of the back of the spokes will make a difference to the strength of the wheels
Blue texta is where it's impacting
Any ideas/thoughts/feelings?
Spacers or get the wheel machined?
That is a lot of metal to be taking out of the wheels.
Can you do anything with the calipers ? (I doubt it)
Methinks spacers are the easiest solution. Are the studs long enough to allow for that?
Use spacers. I run them on the race car. No problems at all. DON'T take metal out of your wheels. If a wheel brakes at high speed it could result in a big accident.
Brett
Brett
I guess 5 or 6mm spacers on a 8 +12 isnt too bad, tried the rears, the don't hit thank christ, spacers with 8.5 +6 wouldnt work at all lol
see if you can grind anything off of the calipers, doubt it but it may be a good solution
Users browsing this forum: No registered users and 175 guests
