Broken alternator belt
- bensale
So I've found a contributing factor to the belt breaking, my front pully has a bit of a wobble... Advice sought in this thread viewtopic.php?f=18&t=32405
www.othersideproductions.com
- TieNN89
SuperMazdaKart wrote:take off the lower timing belt cover, (not the rocker/valve cover one)
mmm lol tried just then
its got a lip which sits behind the rocker cover so
unfortunately I'll have to take the rocker cover off
- SuperMazdaKart
heh, oh well. once you do that you could just leave the bottom cover off.
make sure to have a new valve cover gasket ready just in case.
could even get a 323 BP valve cover, the ones which had a full plastic timing belt cover that can be left off leaving the camshaft gears exposed all the time.
- TieNN89
SuperMazdaKart wrote:make sure to have a new valve cover gasket ready just in case.
it was replace early this year it won't be necessary will it
i got some gasket goo to go in those spots that require it
- Garry
The gasket should be fine. I've reused the one on my cars several times. Just be careful of the gasket when you take the valve cover off. Make sure you tension the bolts on the valve cover evenly when reinstalling them and preferably (though not critically) in the order shown in the workshop manual.
