MX5parts wrote:Add the look of trick
You'd think an English site wouldn't fail English...
Mr Morlock wrote:It certainly looks like it to me. 2 mouldings ring and lid and bracket(s)probably hinged with a roll pin and spring and mounting screws. If it is not plastic it merely demonstrates that the picture and description are inadequate.
Mr Morlock wrote:Rain - This link does not as far as I can see nominate what the product is made of. It looks to me be plastic and metal. If you know what is and its construction then by all means share your knowledge because so far you have not added any value to this subject.
rain902 wrote:and andrew has jsut seen it on the back of my NA - a nice replacement for the broken spring on the original
rain902 wrote:Mr Morlock wrote:The link to me ........
which link? the UK one is not injection moulded plastic with pressed metal bracket attached, you can examine it this sunday if you wish to...
Mr Morlock wrote:Marcusus you are right about the text- they even go on to describe it as "one off". That actually means there is only one. They also say it is "hand crafted" whatever that means.
meanmx wrote:You may note the fact that it says "add the look" which in no way implies that it is a "one off" piece and when it is read as a whole rather than out of context the sentence makes perfect sense. I certainly can find no criticism in it's use of English.
marcusus wrote:I realised after I quoted that I shouldn't have taken it out of context, but I then also realised that it'd be much more fun to leave it taken out of context and see what happened
That being said, even within the context of the rest of the sentence, it still doesn't quite make sense. What the hell is "trick"? I have nothing against the rest of the sentence. It makes perfect sense. Perhaps it's just a bit of English colloquialism that I've never heard of before... something along the lines of tricked up, but just shortened.
Anyway, let the COW continue
