Which glue for softop
- emexv
I need to glue my softop back onto the rails. I don't want to going doing trial and error as it could get rather messy. Is there a glue that is best for this job?
Mark
Mark
Take a look at something like Selleys Kwik Grip- this glue can be used for a variety of things- always very handy in the garage. I cannot recall what group these were called but a number of makers have this style- yellow in appearance bonds a number of substrates - easy to apply with brush or sponge- clean up turps. You apply let it get tacky add some pressure and leave. . I have used it recently to glue carpet to rubber with full success and it is easy to work with. Do not use super glues. A 250ml tin goes a long way and ready for the next job Nevertheless you can ask a knowledgeable retailer or maybe one of the manufacturers has a tech line.
- Matty
- Wuey
- Hot Rodders
Matty wrote:epoxy is a two-part mixture. You could save weight by only using one part.
*Looks around for Wun99*
- PUR157
My advice - don't wast your time with any commercially available product from Home Bunning 10 or similar - I know from experience.
High tail it down to your local paint and panel wholesaler (the local shop where panel shops by tape and sand paper etc) and get a tube of 3M Weather Strip adhesive - it looks like a big toothpaste tube, is about 18 dollars but has the same properties as contact cement but is heat resistant and sicks vinyl to material which is rought the 2 surfaces you will be bonding.
Don't let them sell you any Sikaflex product cause they just dont work.
- Tezzax5
Another one to consider....Shoogoo 2 ? (Not sure of the spelling )
I have used this amazing product for repairing zips in my softtop as well gluing slate tiles back onto the pool coping.
It dries but still remains flexible....but it does take a day to cure
- emexv
Well I decided to give the old Araldite a go. Went to the cite and back for the Fed square display and it held up well. Will have to see how it lasts now.
PS..........Matty I used both parts
Mark
Mark
- Miata Bart
Black silastic is a gift from God when it comes to bodgeying soft tops. I found the original Dow Corning product to be the cats pyjamas. It sticks like poo to a blanket and remains flexible and is UV stable etc etc etc.
Im suprised that no one suggested Tarzan's Grip, its useless for everything. Except making jokes eg:
Boy goes into shop and says "can I have a grip of Tarzan's tube?"
Shop keeper says "what????"
Boy repeats "CAN I HAVE A GRIP OF TARZAN'S TUBE?"
Shop keeper askes "Do you want the stuff that sticks or the stick that stuffs?"
Same boy, different shop, this time its a fish & chip shop
Boy says "Have you got any chips left?"
Shop keeper says "Yes"
Boy says "thats your fault for cooking too many".
Users browsing this forum: Google [Bot] and 156 guests
