OMX-596 - 1996 Spec'd NA6 - Updated 21 Apr 2013
Postby orx626 » Sat Jun 14, 2008 7:05 pm
Here's some piccies and a vid from the Club Trackday held at Queensland Raceway on the 10th June. Thanks to Mr Starlet & 116GTA for the snaps. :D
Vid link -
Re: OMX-596 - 1996 Spec'd NA6
Postby orx626 » Sun Jul 27, 2008 9:36 pm
Got around to fabricating a new exhaust system yesterday! :D
The system is a 2.25" diameter stainless steel system that utilises a NPower rear muffler and XForce extractors. A 2.25" high flow catalytic convertor from NPower was also used. I'm extremely happy with not only the improvement in sound but also the incredible increase in top end performance when compared to the original factory exhaust. I'd never get near the rev limiter previously, but now......it's all too easy :twisted: .
There is no droning or booming either.....the combination works very well together.
Here's some piccies of the build....
Changed out the 2 bolt flange for a 3 bolt.
NPower rear muffler in position with 2 bolt flange removed.
Positioning and tacking of the cat convertor....
Xforce Extractors....
Finished system from front....
Finished system from rear....
Rear end piccies....
Renesis NC waiting for some TLC....
timk
Postby timk » Sun Jul 27, 2008 11:13 pm
That work looks hawt! We'll have to "arrange" something when I decide to upgrade my SE exhaust! :P
TheMissus
Postby TheMissus » Mon Jul 28, 2008 8:40 pm
Every time you post an update of what you've done I am just :shock: in awe.
Postby orx626 » Tue Jul 29, 2008 8:25 pm
saboteur wrote:That work looks hawt! We'll have to "arrange" something when I decide to upgrade my SE exhaust! :P
I'm sure we can come to some sort of "arrangement" Tim 8) .
TheMissus wrote:Every time you post an update of what you've done I am just :shock: in awe.
Thanks Michelle. I'm stoked with the result, the improvement in performance was better than expected....anymore progress on your NA6 :D
TheMissus
Postby TheMissus » Tue Jul 29, 2008 8:42 pm
orx626 wrote:anymore progress on your NA6
Ask me about my favourite subject why doncha Danny? Just stop reading if you get bored :lol:
Most of the stuff except the diff and drive shaft is cosmetic so far. The old soft top leaks more than my racing tape can keep out now and I am a bit over having a wet ass and no fish so this weekend's project is new soft top / rain rails / seals / tension cables, new stereo, bling soft top latches and bling vent rings. A girl does need some bling!
The original engine comes out in the next couple of months so I can start the rebuild and renew. At the moment I am just reading and researching what I want and need to do under the bonnet while we have the engine out. I am thinking we go pretty much back to stock with some paint and a touch of bling so she's pretty as well as functional but ASE05 is trying to convince me to do the CAI and extractors back exhaust and a megasquirt. This could be an ongoing battle ... :roll:
Postby orx626 » Sun Aug 10, 2008 5:02 pm
TheMissus wrote:Ask me about my favourite subject why doncha Danny? Just stop reading if you get bored :lol:
Haha! I will never get bored of cars Michelle. :D
Made up an extension loom to allow the factory oxygen sensor to be reinstalled. This was required because the tapped boss for the oxygen sensor on the new extractors is further down the track.
Have got a bit of heat through the extractors now.....I have also added a mid-length exhaust hanger as well.
Looking forward to Lakeside in 2 weeks! :twisted:
TheMissus
Postby TheMissus » Sun Aug 10, 2008 9:25 pm
Lakeside will be fun ... can't wait to see the mods in person and see what they can do around the track.
Mundi
Postby Mundi » Tue Aug 12, 2008 11:25 pm
Beautiful car mate, love the work that went into it.
Postby orx626 » Wed Aug 13, 2008 4:51 pm
Mundi wrote:Beautiful car mate, love the work that went into it.
Thanks Mundi. :D Hope your 5 turns out just the way you want it! 8)
Postby sliq » Wed Aug 13, 2008 6:21 pm
Danny, i'm no exhaust specialist, but wouldn't a straight through exhaust produce more power than the npower exhausts?
Postby orx626 » Wed Aug 13, 2008 6:35 pm
sliq wrote:Danny, i'm no exhaust specialist, but wouldn't a straight through exhaust produce more power than the npower exhausts?
Absolutely Sliq :D .
However, the exhaust noise would have been obscene on a road car, and my wife would have been most upset :frown: . A turbo would quieten it down a bit though (I'm not going down that path though)....I run a straight through system with hand-built mufflers on my 626 which uses a turboed 13B. It is quite acceptable.
I've found the NPower unit to be a great rear muffler by providing a noticable increase in engine performance without the unbearable noise. It really does sound great when on song above 4000 rpm.
Oh yeah, it looks tops too! 8)
PUR157
Postby PUR157 » Thu Aug 14, 2008 2:09 am
Do you run around with the extractors unshielded?
My car is in a similar sort of state right now and I'm scratching my head as to whether or not I should worry about heat disspiation...
Oneness of Man and Machine
Postby sliq » Thu Aug 14, 2008 11:11 am
don't NA's come with a heatshield, standard?
Postby orx626 » Thu Aug 14, 2008 11:32 am
PUR157 wrote:Do you run around with the extractors unshielded?
Yes, I'm currently running them without a heatshield. The reason for a heat shield is to protect surrounding items from excessive heat. I will be fitting a heat shield in the not to distant future.
If you are concerned about heat dissipation from the exhaust gases then a heat shield is not the best solution. I recommend having the extractors ceramic coated (especially if they are mild steel) inside and out (ie. HPC) and installing a heat shield. This will reduce heat exposure of surrounding items and will also keep the exhaust gas energy higher.
Users browsing this forum: No registered users and 114 guests
