Braided Brake Lines? worth it?
- Mr Starlet
Hi all
Just seeing what your thoughts are regarding braided brake line, are they worth installing? I've came across numerous reviews that recons they're a waste of money, they recon there's no noticeable pedal improvement, are they even road legal here in QLD?
Minh
Minh
Its around the $200 mark for ss lines (ADR aproved) + 8 bucks for new fluid.
I just installed mine about 2 weeks ago (2001 NB8B). I think the older your OEM lines the more difference you will notice. Considering old lines will give and expand more.
I do notice a difference in \"firmness\" I had to bleed in new fluids so that may also have contributed to the more \"firm feel\". I estimate its around 10% more firm, dont have to press the pedal as deep to have bite etc.
Its not a missive wow difference but overall Im happy I installed the ss lines.
every ounce counts
- Mr Starlet
- 16bit
- 16bit
- CT
- AJ
wun911 wrote:Did the review compare new lines to SS lines? I think the difference is greater as the line gets old...
If you press the pedal hard on old lines you can visibily see the lines expand in that case surely it cant be a 1% differnece.
bloody hell wun!!!........your eyesight must be unbelievable, no WAY brake line expansion is visible to the naked eye
XMX5 Rogues
- 16bit
CT wrote:Every proper race car in the world uses braided lines...you can use that as a reference. Roads cars don't really need them but even HSV and FPV fit them to their performance models.
I would say thats got more to do with reliablity under extreme conditions then how much they expand - that and manufacturors of road cards don't do it on a lot of cars because its more expensive and the normal lines work just fine.
- Steampunk
16bit wrote:CT wrote:Every proper race car in the world uses braided lines...you can use that as a reference. Roads cars don't really need them but even HSV and FPV fit them to their performance models.
I would say it's got more to do with reliability under NORMAL conditions James
I think I found the article 16bit read.
http://autospeed.com/cms/article.html?&A=2679
Its only a 1% difference
every ounce counts
Users browsing this forum: Google [Bot] and 282 guests
