Centre brake light not working
bigdog
King of the kennel
Postby bigdog » Wed Jul 16, 2008 12:06 am
And no, it's not the bulb - changed it twice just in case :D Any thoughts on why this might be? I assume it is not separately fused and works in circuit with the main brake lights? The loom looks to be intact so I'm kinda scratching my head on this one. When I get a minute I'll go over everything with a voltmeter and try and sort it out, but I thought someone may have come across this before??
SuperMazdaKart
Postby SuperMazdaKart » Wed Jul 16, 2008 12:51 am
it's common on NAs since the wiring tied to the bootlid hinge breaks after lots of bending from the bonnet going up & down
Last edited by SuperMazdaKart on Thu Jul 17, 2008 1:59 pm, edited 1 time in total.
Brad
Postby Brad » Wed Jul 16, 2008 7:47 am
Yeah, likely the wire. Mine's broken several times, most recently the earth wire was broken somewhere back into the loom so I had to run a separate earth wire.
Juffa
Postby Juffa » Wed Jul 16, 2008 9:30 am
^^ what they said. It might not be obvious to the eye as the insulation around the wire can be intact, but the wire itself can be broken.
J
Steampunk
Postby Steampunk » Wed Jul 16, 2008 9:32 am
Ditto ^^
simple enough that even I fixed it all by my very own.
Does your horn still work? apparently the third/high mount brake light is on the same circuit.
Brad
Postby Brad » Wed Jul 16, 2008 10:12 am
Strangly enough, my centre light worked while the boot was up, so as I was testing it with the multi-meter, all was good, yet I was still being told it wasn't working. The boot needed to be closed to break the circuit.
Postby bruce » Wed Jul 16, 2008 11:08 am
Plus, your rear was repaired, so it may be related to that ?
bigdog
King of the kennel
Postby bigdog » Wed Jul 16, 2008 10:33 pm
Yep - thats what I was thinking. It is likely a break up near the hinge area methinks. I will also check the horn is working tomorrow. Thanks guys! :D
Postby Mr Morlock » Thu Jul 17, 2008 2:42 pm
If you have someone activate the brake you can check with multimeter or test probe to see if the wire is hot.. and trace back. I would have thought the centre high mounted stop light would be on a different circuit to your rear combo lights as a safety feature. If the fuse goes you would expect one circuit to still function rather than lose all 3 stop light function.
bigdog
King of the kennel
Postby bigdog » Thu Jul 17, 2008 9:43 pm
Checked the manual - same fuse runs all brake lights and horn, so its not that, therefore must be the wiring. Will do some meter work shortly...
Richee
Postby Richee » Thu Jul 17, 2008 10:01 pm
bruce wrote:Plus, your rear was repaired, so it may be related to that ?
I wouldnt go talking about bigdogs rear if I was you Bruce :mrgreen:
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
bigdog
King of the kennel
Postby bigdog » Fri Jul 18, 2008 2:51 pm
:oops: :mrgreen:
Postby sliq » Fri Jul 18, 2008 4:19 pm
bigdog have you ascertained what the problem was?
bigdog
King of the kennel
Postby bigdog » Fri Jul 18, 2008 4:49 pm
Not yet... won't get a chance till Sunday. Will let you know :D
bigdog
King of the kennel
Postby bigdog » Sun Jul 20, 2008 8:18 pm
Simple to fix - two broken earth wires in the loom at the boot hinge, one for the centre brake light and one for the right hand boot/number plate light. all good now :D
