Annoying squeaking sound
- sliq
Hey Guys,
My car has this very annoying squeaking sound whenever i'm on bumpy road, or pretty much anything that makes my car vibrate. It sounds like there are mice in my car.. Squeak Squeak!
It first started coincidentally when i removed my centre console.. I removed the console again this morning and tightened up all the bolts.. Still same squeaky sound whenver I go over bumpy road or speed bumps..
Any clues? I've tried reading up on miata.net but no help there..
TIA.
TIA.
- redwards
- sliq
JBT wrote:If you think it has something to do with the console, take it out and test drive.
I had a squeek in my NA - it was actually the rubber stoppers for the boot lid. A very thin smear of Armorall fixed it.
yup, i removed the centre console and took it for a drive around the block, still squeaky squeak.
- Gazbo
I found that my radio was rubbing against the inside of the console, a bit of foam tap fixed that.
Then the metal clips that the radio screws into started rattling, more foam tape...
The bonnet tends to squeak on the catch and rubber stoppers. Lubricate the catch and put felt pads on the rubber stops.
I also found the door trims (cards) would squeak against the door. I padded this with yet more foam tape.
A dull plasticy rattle turned out to be sides of the dash vibrating. I'm referring to the part that is covered by the doors when closed. This was solved by stuffing the cavity between the metal dash ends and the plastic ends with blocks of soft foam. This stops the plastic resonating, hence no more rattle.
Also try securing any loose cable looms behind the dash with cable ties.
Could I recommend you buy a roll of foam tape?
I still have a metallic buzz coming from the centre console which occurs around 3000-3500 rpm. Very annoying, and I just can't trace it. I'm sure it's NOT heat shields rattling.
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
Fun: 1993 NA6
- Garry
Try moving the bottom of the dash down near where the console attaches. If you hear the squeak it could be the screw near the back of the centre pocket in the console just in front of the heater box that holds the dash to the transmission tunnel. You'll need to climb in behind the dash to tighten it up with a stumpy phillips head screw driver. While your under there you can tighten up all the other screws that hold the plastic dash to the metal frame, they will probably be loose too.
- chrislevingston
- chrislevingston
- Patty
i just recently got a squeak too sounds like its from the passenger side near my seat, i shake my seat but it doesnt squeek, i'll find it this weekend with this bad boy http://granitegrok.com/pix/soldier_size_mouse_trap.jpg
- sliq
MXHEVN wrote:i just recently got a squeak too sounds like its from the passenger side near my seat, i shake my seat but it doesnt squeek, i'll find it this weekend with this bad boy http://granitegrok.com/pix/soldier_size_mouse_trap.jpg
LOL!! and to think these soldiers were trained to be in danger.. tsk tsk.. hehe
if that yank was smart enough, he'd be pulling the beer from the other side
Users browsing this forum: No registered users and 155 guests
