Annoying squeaking sound
Postby sliq » Tue Jul 15, 2008 4:13 pm
Hey Guys,
My car has this very annoying squeaking sound whenever i'm on bumpy road, or pretty much anything that makes my car vibrate. It sounds like there are mice in my car.. Squeak Squeak!
It first started coincidentally when i removed my centre console.. I removed the console again this morning and tightened up all the bolts.. Still same squeaky sound whenver I go over bumpy road or speed bumps..
Any clues? I've tried reading up on miata.net but no help there..
TIA.
Steampunk
Postby Steampunk » Tue Jul 15, 2008 4:29 pm
I had a similar sounding squeak. Came from my ECU mounts.
If its coming from the passenger side, check that the passenger footwell plate and ECU is tight.
Alex
Postby Alex » Tue Jul 15, 2008 6:35 pm
my passenger seat squeaks when empty, I just recline it as much as it will go so it's wedged against the BD bar to put some pressure on it and it stops
JBT
Postby JBT » Tue Jul 15, 2008 8:27 pm
If you think it has something to do with the console, take it out and test drive.
I had a squeek in my NA - it was actually the rubber stoppers for the boot lid. A very thin smear of Armorall fixed it.
redwards
Postby redwards » Tue Jul 15, 2008 8:56 pm
... and the switch on mine that told the alarm that the bonnet was open squeaked on mine.
Mate, it could be anything! I'd suggest (gently) pushing and pulling on your centre console and see if you can reproduce the squeak. It'll be easier to find then.
Former owner of a white 1994 NA8 Clubman
Postby sliq » Wed Jul 16, 2008 12:23 am
JBT wrote:If you think it has something to do with the console, take it out and test drive.
yup, i removed the centre console and took it for a drive around the block, still squeaky squeak.
Gazbo
Postby Gazbo » Wed Jul 16, 2008 9:03 am
I found that my radio was rubbing against the inside of the console, a bit of foam tap fixed that.
Then the metal clips that the radio screws into started rattling, more foam tape...
The bonnet tends to squeak on the catch and rubber stoppers. Lubricate the catch and put felt pads on the rubber stops.
I also found the door trims (cards) would squeak against the door. I padded this with yet more foam tape.
A dull plasticy rattle turned out to be sides of the dash vibrating. I'm referring to the part that is covered by the doors when closed. This was solved by stuffing the cavity between the metal dash ends and the plastic ends with blocks of soft foam. This stops the plastic resonating, hence no more rattle.
Also try securing any loose cable looms behind the dash with cable ties.
Could I recommend you buy a roll of foam tape?
I still have a metallic buzz coming from the centre console which occurs around 3000-3500 rpm. Very annoying, and I just can't trace it. I'm sure it's NOT heat shields rattling.
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
Garry
Postby Garry » Wed Jul 16, 2008 9:14 am
Try moving the bottom of the dash down near where the console attaches. If you hear the squeak it could be the screw near the back of the centre pocket in the console just in front of the heater box that holds the dash to the transmission tunnel. You'll need to climb in behind the dash to tighten it up with a stumpy phillips head screw driver. While your under there you can tighten up all the other screws that hold the plastic dash to the metal frame, they will probably be loose too.
chrislevingston
Postby chrislevingston » Wed Jul 16, 2008 2:08 pm
Is this your car?
That would explain the squeak :mrgreen:
1990 "TOY MX5" - Red, of course!
Kings, Konis, LSD, Genie system, grille, Voodoo knob, braces, 14 degrees ATDC, woodgrain dash,style bars and lots of work making the rubber bands go around faster.
Steampunk
Postby Steampunk » Wed Jul 16, 2008 2:25 pm
chrislevingston wrote:Is this your car?
No it wouldn't
chrislevingston
Postby chrislevingston » Wed Jul 16, 2008 2:43 pm
You are right - the Squeaker has escaped :frown:
Patty
Postby Patty » Wed Jul 16, 2008 4:08 pm
I once had an auto Pajero iO where the overdrive button had some play in it and squeaked. Drove me nuts trying to find where it was coming from. I know this doesn't help you at all, just thought I'd share. :lol:
Grace Green NB8A
RG.net
Postby RG.net » Thu Jul 17, 2008 8:04 pm
i just recently got a squeak too sounds like its from the passenger side near my seat, i shake my seat but it doesnt squeek, i'll find it this weekend with this bad boy http://granitegrok.com/pix/soldier_size_mouse_trap.jpg
Postby sliq » Thu Jul 17, 2008 10:57 pm
MXHEVN wrote:i just recently got a squeak too sounds like its from the passenger side near my seat, i shake my seat but it doesnt squeek, i'll find it this weekend with this bad boy http://granitegrok.com/pix/soldier_size_mouse_trap.jpg
LOL!! and to think these soldiers were trained to be in danger.. tsk tsk.. hehe
if that yank was smart enough, he'd be pulling the beer from the other side :P
zawrilla
Postby zawrilla » Sat Jul 19, 2008 3:56 am
squeaking for me too.
Being an older car, there's soooo many things that could be the cause, I don't think I'll ever find it.
