Postby Okibi » Thu Jul 10, 2008 10:02 pm
Theres a philips head screw on the metalic bits at the back of your hardtop. Look on the inside edge of both (i think) take that screw out, the top part of the metalic piece will pivot across, then you can adjust the 2 bots that hold the C shaped part that grips the Frankenstein bolts.
It will make more sense when you do it.
