Windscreen & Wipers - NA & NB
- Locutus
oohhhh... i'm up for nozzles & wipers if there's a GB
shouldn't the little deflector be on the driver's side?
mr_rotary wrote:I have fitted NB windscreen wipers to my NA6 and they are almost identical. The only difference is the small metal wind deflector on the passenger side wiper on the NA6. Wiper blade length is exactly the same.
- MX5CHIC
Hi there,
I recently purchased a new set of Trico Neoform Beam Blades for my NB8A, they work great and look a lot better.
I bought them from Repco at Mascot, if you need the Part number it is - 16-180 / 18inch.
BTW - Retail is $23 each
- Mr_Q
- MX5CHIC
I drove in the rain for the first time since installing the Neoform Wipers at 110 Kmh (on the freeway)
My humble opinion is that they hold better against the screen with no lift , and secondly; they look better without all that metal above the blades.
I just had a new windscreen installed so I thought i'd go overboard and get a new set of wipers as well, some people are surely and understandably going to be of the opinion that $23 per blade is excessive.
As to rubbers drying out from the sun, I use the 303 Aerospace Protectant on all the rubber and plastic areas of my car, sure it's expensive but when I was quoted $555.00 for replacement window rubbers on the MX5 I realised it was cheap protection.
Nice to see that these blades are now available. I couldn't find them from the usual Auto outlets when i was searching a few months ago. Will definitely buy them next. The stock blades stick out too much for my liking. They are hideous. I want these for the looks . Normal blades already give the perfect wipe. I clay and rainx my windscreen so the blades are not needed as often. I like watching the water just slide off. I love driving in the rain with the sound of water drops hitting the soft top....easier to bring the back out as well.
Wait's for the next 20% off sale.
- Garry
Mr Morlock, I've heard, though haven't actually tried, that on the Bosch version you can prise one end off and replace the rubber blade with a regular trico blade after the original blade has worn out.
- philz
- Wheel guru
I use the Aunger [complete set] ones from Supercheapauto, I didn't expect much from them for $11, because i bought some previously for my Toyota Starlet and being \"universal\" wipers they weren't that great.
But when I fitted them onto my Nb8a, they were PERFECT, caught me by suprise. So I would highly recommend them, very cheap.
Forget the part number, but iirc they were the 40 or 45cm ones, check the back of the wiper application.
- Boags
I'm up fora group buy. Who is organising it? (I'm certainly not, I need a vacation after the last lot!)
- Boags
Calling SM. Are your fingers painted on? Start sending some emails.
Users browsing this forum: No registered users and 55 guests
