lsd questions - before and after
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Jul 07, 2008 1:39 pm
Just wondering if anyone has any data on before and after track times with an lsd. I have just purchased an lsd and was wondering what sort of improvements others have gained from the mod. thanks.
Fatty
Postby Fatty » Mon Jul 07, 2008 8:22 pm
you'll get much more drive out of corners. i found it really tends to straighten you up and you can get the power down a lot better as you are exiting the corner.
irwin83r
Postby irwin83r » Mon Jul 07, 2008 8:46 pm
depends on the track really.
at wakefield (very short tight track) i hear its about a second?? but thats just a number i heard someone mention in conversation.
however through my own experiences id say it would be atleast a second at wakefield... makes a HUGE difference coming out of the fish hook...
marcusus
Postby marcusus » Mon Jul 07, 2008 9:33 pm
irwin83r wrote:makes a HUGE difference coming out of the fish hook...
I reckon that'd be where it'd make the most difference there. When I take it at power, I can feel the wheels slipping, so it'd be great to have the power down going round there.
matt9111
Postby matt9111 » Mon Jul 07, 2008 9:33 pm
Just a question, im pretty sure my car has a viscous LSD....I've heard you can get extra shims put in them to make them lock harder, to the point where you can get them to act as a completely locked diff....and its only like $300.
Just wondering if anyone has had this done, if its possible and also if they've dríven a car with a proper LSD, and whats the difference?
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
Boags
Postby Boags » Tue Jul 08, 2008 8:10 am
Sorry James; no times to post. But I can tell you I didn't realise the inside was slipping until I put the LSD in and it didn't do it anymore. :shock:
Massive difference.
Matt: you can't make a viscous diff act like a locked diff. They will never lock as well as other types of LSDs. From what you describe you have a clutch pack diff. If you shim the diff you can get the clutches inside to be very tight against each other and act pretty much like a locked diff.
HTH,
Boags
