marcusus wrote:Why not just stop the car whilst in neutral, then put it in gear? That's what I do...
One needs to have the car in gear, in order to move it into the parking spot...
wun911 wrote:The little black rubber stoppers didnt help one bit??
My dad's car you cant start the car unless your foot is in the clutch. Is this difficult to wire up into an MX5?
Caffeine wrote:wun911 wrote:The little black rubber stoppers didnt help one bit??
The US model MX5 has that feature, but it wouldn't have helped in this situation...
oongie wrote:The same thing happened to me, but I was on the receiving end... now I have one hole where the screws were...
I immensely dislike Parramatta Westfield carpark...
Cheers Paul
Boags'MX5 wrote:Caffeine wrote:wun911 wrote:The little black rubber stoppers didnt help one bit??
And they disable it because it is annoying.
Fatty wrote:Boags'MX5 wrote:Caffeine wrote:wun911 wrote:The little black rubber stoppers didnt help one bit??
sure it might be annoying, but if the aus spec cars had this feature, i would still have the original door on my car!
AJ wrote: I am completely OVER all these bullshit devices that stop people making mistakes, like beeping so you don't lock your keys in the car.........not that you can do THAT in an NC anyway, you physically can't lock the doors manually with the key in the ignition.
