Chasing leaks
Chasing leaks
Postby Jeo » Thu Jul 03, 2008 8:56 pm
While washing my car the other day, NA6 for those of you playing at home, my girlfriend who was sitting in the car noticed that there was water dripping off the accelerator pedal. On closer inspection the drivers floor mat was fairly wet, but I couldn't see where it was coming from. I've never noticed it before, but then again I wouldn't notice a wet floor mat as I wouldn't have bare feet.
Has anyone else seen this happen before? Any ideas where it could be coming from?
Fatty
Postby Fatty » Thu Jul 03, 2008 9:16 pm
well i'd be guessing that you might have a leak somewhere.
Boags
Postby Boags » Thu Jul 03, 2008 9:22 pm
Fatty wrote:well i'd be guessing that you might have a leak somewhere.
Hey; he's right! Water is getting from the outside to the inside! :shock: :mrgreen: :P You are so learned, fatty.
Welcome Jeo! (I hope that isn't a typo and your name is actually Joe. That'd be funny)
Anyhow; were you washing the engine bay? There are some holes in the firewall for wiring to go through, and water could get through them and wet your floor mat.
Good luck with it. :D
Boags
Stu
Postby Stu » Fri Jul 04, 2008 12:35 am
I don't suggest using one of the Laser washes to find the leak. :oops:
Garry
Postby Garry » Fri Jul 04, 2008 10:55 am
My friend had a similar leak in her NA6. The weld that held one of the relay brackets on under the dash had cracked and water was coming in from the air plenum at the base of the windscreen.
Postby Jeo » Fri Jul 04, 2008 2:03 pm
Hehe, yep real name is Joe but on 'teh interwebs' I'm Jeo.
Nope, wasn't washing the engine bay at the time but its still probably worth checking.
I had noiced that the relays weren't attached to anything when poking around under the dash yesterday so that would make sense Garry.
Thanks all
Steampunk
Postby Steampunk » Fri Jul 04, 2008 5:06 pm
who was it that posted, late last year, a similar-sounding leak.
A guy from Sydney I think. His footwells became pools after being parked in the rain overnight.
:roll:
Chasing leaks
Postby Jeo » Fri Aug 29, 2008 12:57 am
Just in case future people were wondering how I fixed the problem, as per Garry's advise, water was coming in at the bottom of the windscreen. Chased back to where that relay bracket had broken off and jammed it full of silicone. It didn't look like a hole, nor could I see through it, but its a few wet months later and I haven't seen any problems since.
Thanks again Garry :)
Garry
Chasing leaks
Postby Garry » Fri Aug 29, 2008 9:39 am
Glad to help :mrgreen:
Users browsing this forum: No registered users and 163 guests
