fuel pump question
- 16bit
fuel pump question
if I install a new higher capacity fuel pump will I need to get a new tune done?
- Garry
- 16bit
the walbro pump has more fuel pressure, hence it will deliver more fuel (effectively it's the same as upgrading to bigger fuel injectors). so i would've thought a new tune would be needed?
whilst i see what kula is saying about the fpr.. i thought the fpr is expecting a certain pressure, you give it a higher pressure to start with and it will output a higher pressure as well.
i could be talking out of my ass, but i had a feeling it does effect the tune.
- Woo
- Vehicle: 10AE - Turbo
The regulator will increase the volume of fuel flowing back to the tank in order to keep the pressure at it's factory preset level.
So the pressure doesn't get higher unless the regulator cant handle the increased flow. This sometimes happens if you put a 255 LPH pump in instead of a 190 LPH.
The increased flow has some benefits due to the fuel being kept cool rather than sitting in the rail getting hot.
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
