Magnecor or Top Gun Ignition Leads
Hi all, I am thinking of going to the red 8.5 Magnecor ignation leads but I believe a lot of folks run Top Gun so...I thought I would ask for opinions - good, bad, which is preferred, the respective value for money etc.
My Eunos is still being built but no plans to change the stock engine so is it a worthwhile mod?
Wait to hear.
Wait to hear.
i just got some OBX-R leads for my mx today, these are 10.5 mm thick and are alot better then stock, not sure on comparison to magnacore and top gun, but i have heard that magnacore tend to break. i got these plugs for $60 from us ebay.
- Ajay
actually, i think they are 10.3mm either way they are thick lol very good quality too
- SuperMazdaKart
- Boags
Mr Morlock wrote:I am not sure why you need to use anything but a good quality std lead for a stock engine. Shelling out extra cash is not likely to give you any benefit.
The aftermarket ones are, more often than not, cheaper than genuine Mazda leads. You can get standard replacement from Supercheap or Repco; but then you have to ask yourself if you are still using a "good quality" lead.
Boags
How often do you replace spark plug leads? For a standard petrol car being dríven \"normally\" you probably never replace them. Where leads can show deterioration is for lpg installations- I had a Disco on gas and the popping and banging was fixed with a lead change. The Top Gun leads were made in Aust some years ago and I saw two of the plants that did them. Quality was good. Not sure where they are sourced now. But Boags is right- it is not always easy to know what is good and what is not.
my stock leads were buggered on 136---kms (unless changed by previous owner) but they were starting to fall apart i.e rubber bottom came off, and plastic piece also came off, car ran poor and liked to idle jump whislt having indicators on and turning, didnt like starting up when hot (quick run in to the shops) i put these obx leads in, and that has all changed. as for oem quality, it fell apart in the end lets see how long these ones last.
Users browsing this forum: No registered users and 117 guests
