IAT Location
fly
IAT Location
Postby fly » Fri Jun 20, 2008 5:59 pm
Hi all,
Is the location of the IAT sensor for MSPNP critical? I was considering drilling and tapping the inlet manifold just after the thottle body, or should it be installed on the intake side of the TB.
Any thoughts.
Dave
pretty fly for a white car
Matty
Postby Matty » Fri Jun 20, 2008 9:01 pm
Doesn't really matter, but I'd suspect that a sensor mounted into the metal of the manifold would heat soak pretty badly.
Steampunk
Postby Steampunk » Sat Jun 21, 2008 1:02 am
Doesn't it state in the instructions where the optimum place to locate it?
I haven't installed mine yet, but I was going to put it as far away from the exhaust as possible.
zoomzoom has his about 30cm from the throttle body.
fly
Postby fly » Sun Jun 22, 2008 1:07 pm
The instructions recommend mounting after anything that will change the air temp, eg turbo, supercharger, intercooler etc.
My main concern is whether or not the IAT body need to earthed.
Big G
Postby Big G » Sun Jun 22, 2008 7:42 pm
Here's a pic of mine seems to work well
Geoff
Growing old disgracefully in Queensland
Founder of Eastern Region[HMF] Sunshine Coast Chapter.
1990 Mariner Blue Roadster
Verithin Guitars
bark
Vehicle: NA6 - Turbo
Postby bark » Mon Jun 23, 2008 9:16 pm
I located my IAT before the throttle body on the intercooler pipe after the intercooler, about 30-50mm before the throttle body.
tinsfci
Vehicle: NA - V8
Postby tinsfci » Tue Jun 24, 2008 1:33 am
Big G wrote:Here's a pic of mine seems to work well
Well it wasn't THAT good, because it made all of you intake manifold pop off and land on the floor! :P
I had my IAT in the base of a metal pod filter and it registered up to 85 degrees or so. It may have been picking up a lot of heat from the metal base of the pod. I think it would be better mounting in a plastic pipe if possible, but I have no idea if it really matters and it may not be possible with a turbo.
Street='94 with FFS Coldside. Sold :(
Race='97 with AVO (soon to be Absurdflow) and GT2560 <--- sod that... LS1 conversion underway!
jerrah
Re: IAT Location
Postby jerrah » Mon Aug 09, 2010 10:16 am
Has anyone worked out an ideal location?
I'm tossing up between sticking it in the intake manifold or mounting it in a spacer between the intake manifold and throttle body.
1991 MX5
Juffa
Re: IAT Location
Postby Juffa » Mon Aug 09, 2010 11:19 am
I used to have a turbo installed on Tweety. I had a hard plastic pipe attached to the intake manifold at one end and intercooler at the other end. I drilled a small hole in the plastic pipe about 2.5 cm before the intake manifold and sealed it in with some Selleys Knead IT
This was the position recommended by Flyin Miata for the IAT used with the FM/Link ECU that I had at the time.
J.
jerrah
Re: IAT Location
Postby jerrah » Mon Aug 09, 2010 4:45 pm
Does kneed it bond to PVC?
1991 MX5
Steampunk
Re: IAT Location
Postby Steampunk » Mon Aug 09, 2010 8:52 pm
There's several types of Knead It according to application, so one of them should do the job for you.
