Fuse box - help please
suzi
Postby suzi » Fri Jun 20, 2008 7:47 pm
I have done a quick search with no luck - freinds are stuck in the dark somewhere & cant find the fusebox of their NA6?
Suzi
Sunlight Silver 2002NB (Suzi)
bensale
Postby bensale » Fri Jun 20, 2008 7:56 pm
Its on the drivers side, behind the plastic surrounding the footwell, under the steering wheel near the pedals.
There are two screws you remove from the bottom of a large central plastic cover which leads down into the footwell. You remove this piece of plastic and look behind the plastic to the right (away from the centre console). Its located in that space, it helps to use a torch as it is difficult to see.
I'm not sure if this is detailed enouth, but should help. If they are in the dark and dont have a torch they may be in trouble...
www.othersideproductions.com
suzi
Postby suzi » Fri Jun 20, 2008 8:02 pm
Your a legend - thank you muchly!
That should get them out of trouble till they get here...
Thanks
Suzi
bensale
Postby bensale » Fri Jun 20, 2008 8:33 pm
No worries, my pleasure. Hopefully what ever the problem is isn't too dificult to rectify.
Ben,
suzi
Postby suzi » Sun Jun 22, 2008 11:48 pm
Appears this is turning into an intermittent problem.
Friends are off to the auto elec tomorrow although we suspect the recent immobiliser install may have something to do with the problem. Apparently the wiring near the fuse box now looks like a dogs breakfast :shock: so they will seek out someone else to tidy it up.
Thanks again Ben for your help.
Suzi
