Corksport
IL Motorsport \"TypeR\" brand
Plasmaglow
Coloured bulb condoms worked best but fade every 6-12 months, where did you get the Refractor Blue 5 LED Wedge Bulbs?
I eneded up putting the LEDs into my Mazdaspeed dash.
mx5boi wrote:...P.S. It has always annoyed me too that there is no light advising whether the fog lights are on or off...
Hammer wrote:
I do a lot of night driving, how do you find the blue lights at night? Are they too distracting? Plus is the uneven light intensity around the speedo and tacho, annoying?
Plus while we're at this topic, any advice when removing and putting back in? What to avoid etc. I'm thinking at also putting the extra light for the "Fog lights-on" warning.
I'm worried once I pull it apart, when I put it back, it won't be as snug and tight fitting as when it came on from the factory.
Mr Morlock wrote:marcusus I thought that mxhevn was joking.. isn't he?
mx5boi wrote:I still have not managed to even get the 'cowl' off the dashboard. I have pulled and tugged and yanked - Nothing.
I know there are four 'clips' that hold it in place that need to be released first. Plus another two right at the front base (one each side) which are 'unclipped' after you manage to 'yank' the cowl from the main dash but.......
Where are these four clips?
Are they attached to the cowl or the main dash?
Are they at the rear or the sides.. or both?
Am I supposed to pull 'Up' or 'Out'?
If I know where they are and how they attach and what they looked like it might help????
Every report has read "Be careful not to break the four clips as you yank the cowl off" - but I have tried with all the power that I have and I cannot get these elusive clips to release. It is driving me to distraction.
I will have another go tomorrow.
I have a sneaking suspicion that I am going to eventually end up with a cowl in one hand and four 'separated' clips lying on the floor.....
mx5boi wrote:Where are these four clips?
