monza wrote:Fantastic piece of plagarism on behalf of autospeed then.
I come from a nissan background and this is a common mod on na sr20's and rb 20/25's. I am no engineer, nor do I understand much about it but common sense says the most effective route will be the shortest with the least restriction. That is the basis for my experimentation.
On what basis did you think the nb8b was good? I just saw 1.5m of bent different size hose with a number of choke points. As I said I am new to mazda but it's the most convoluted OEM induction system I have ever seen.
I didn't do it for noise. It was a genuine attempt to extract more torque. The fact that I had not seen anyone do it just made me keener to try (I also accepted that there was probably a good reason why no one was doing it
Why would I test the existing plumbing? If my mod reduces torque (as determined through a before and after torque curve map) to a degree were I believe the gain in throttle response is offset by any drop I put the original kit back on and start again.
As I said, I have very little idea about the technical side of it. I work on very basic principles and am happy to have my concepts disproven (preferably by myself) which is why I will be doing more than seat of the pants testing.
nonono, autospeed asked me to write that article for them. No plagiarism, I have the authoring credit.
I
suspect the NB intake is good based on inspecting it and my experience with the NA6 measurements.
The AFM-TB duct is a decent size (in the context of the power level of a standard engine) and has nice large bends in it.
The air flow meter is a hotwire design that is usually less restrictive than a vane meter. (can probably pop out the mesh for a fractional improvement)
The airbox - I haven't really looked closely at, but the snorkel is shorter than the NA's and comes to the front so will be sucking cooler air.
But until it's measured, anything else is heresay. Personally I don't see the point in "improving" something without knowing how good it is to start with, or without measuring your results...
I'm not at all saying you can't improve on it, but I suspect the improvements in flow will be small (cold air is another matter).
