Wheel Weight?
TieNN89
Wheel Weight?
Postby TieNN89 » Fri Jun 13, 2008 8:43 pm
I was wondering how many kilos above the stockos will i start noticing something different
What happens if my wheels are slightly heavier
Say if i go from my (NB8A Stock weight) 13.1lb = 5.9kg to 7.6kg
15x6 to 15x6.5 Offset 38mm
or to 8.2kg 16x7 Offset 42mm
Will I notice anything different and will going up a size change anything?
PUR157
Postby PUR157 » Sat Jun 14, 2008 2:47 am
When I had a go in Zawrillas car way back when... Late model NA... it had huge rims on it that looked heavy as hell (I think he said they were heavy as hell too)... but when I got behind the wheel I didn't notice a thing... the power steering seems to mask the effect of them (the effect of feeling heavier at least)
As for numbers... Track guys would probably be able to give more useful information?
Oneness of Man and Machine
TieNN89
Postby TieNN89 » Sat Jun 14, 2008 7:36 am
yeah
well i can't understand how it would make any difference except for the car weighing more overall
so i thought i'd ask before i go out and order these rims
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sat Jun 14, 2008 9:18 am
increasing un sprung weight is one of the worst things you can do to a small car. much like the above comment handling will be worst - especially if you keep stock suspension that was designed and setup for the oem rims.
Adam_NAclubman
Postby Adam_NAclubman » Sat Jun 14, 2008 1:07 pm
You'll also find that you need to flare the revs and slip the clutch more to move from a standstill, mine always feels soooooo much better when I put my 14's back on
wun911
Postby wun911 » Sat Jun 14, 2008 3:30 pm
Not only is the rim un-sprung weight the wheel is considred rotational mass. As it spins inertia takes place.
Personally if you gave me the choice I would rather lose 1 kg off a wheel than 4 kg of static weight off the body of a car.
Some belive that reducing the profile of the tyre, due to the larger rim also reduces the weight of the rubber slighly (less rubber in the side walls). And the reduced weight of the rubber is more imporant because its on the outer edge of the rotational mass. In theory it makes sence but no one has proven it to me in newton meters.
every ounce counts
PUR157
Postby PUR157 » Sat Jun 14, 2008 6:29 pm
That would be similar reasoning as to why Autocrossers in the states have like... 13\" rims with 45 section tyres... I guess :lol:
Boags
Postby Boags » Sat Jun 14, 2008 7:43 pm
I could always tell the difference between track rims and road rims.
Track rims did have semis on them though, but the weight difference was about 2kg/rims (with tyres on).
It was always so much easier to drive and steer with the road rims/rubber on.
Boags
TieNN89
Postby TieNN89 » Sat Jun 14, 2008 7:52 pm
DAM
I like the wheels but the weight got me concerned since people were talking about wheel weights
Anyway looks like I won't be getting them and leave it to the last option
Boags, You know those starcorp rims you have are they shiny? I don't like having a full wheel that is chromed I'd rather have just the lip but they say its shadow chrome but I\"m not sure how blinggy they are
What options do i have for rims around the $800 mark a full set (4 wheels) which are around the same weight as the stockos
Gazbo
Postby Gazbo » Sat Jun 14, 2008 11:27 pm
I really notice the difference between my NB 15\" rims with 205/50 tyres and the standard 14\" 185/60 daisy wheels.
Acceleration is more sluggish with the 15\" wheels (greater rolling diameter and greater rotational inertia), plus worse ride quality.
The grip is much better with 15\" wheels, but that's likely to be the particular tyres fitted.
I don't think the MX-5 is all about grip anyway, it's the balance and feel. I much prefer the standard little skinny 185/60/14 wheel/tyres, the car dances around more and feels nimble.
Big wheels and tyres on an MX5 are like a ballerina wearing army boots!
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
TieNN89
Postby TieNN89 » Sat Jun 14, 2008 11:37 pm
well my plans are to keep the stock sizes
TieNN89
Postby TieNN89 » Sun Jun 15, 2008 12:45 am
PUR157
Postby PUR157 » Sun Jun 15, 2008 4:42 pm
I do hear the 17 brigade piping up once in a while about what all the hubbub is about with big rims, so each to their own really!
Just decide what your needs are... if it's possible borrow a set of rims from someone else for a test fit? See how you like them?
TieNN89
Postby TieNN89 » Sun Jun 15, 2008 5:06 pm
Sasso wrote:I wouldn't go above 6kg/rim unless they looked pretty damn good, and you have the power to spin them.
:shock: i never knew my car was a slow piece of sh*t
Boags
Postby Boags » Sun Jun 15, 2008 6:39 pm
Tien,
The starcorps aren't too shiny. I was worried about that too; the only colour available when I was buying was the \"shadow chrome\". They are great though, not mirror finish like chrome.
Boags
