Designing a locost style Lotus 7 Replica
Discussion regarding putting a non MX-5 engine in your MX-5, Exocet, Locost, FM Westfield and other MX-5 based kit cars.
Moderators: timk, Stu, -alex, zombie
Mokesta
Postby Mokesta » Thu May 29, 2008 11:47 am
Further to my earlier comments re torsional stiffness. It is relatively easy to pass the Qld requirements for a 4 clyinder. The car I was referring to had a v8 so it needed extra stiffness. Of course, I would want to surpass teh minimum requirements by a fair degree because a high torsional stiffness will enable far greater suspension tuning accuracy and handling predictability. So you may not \"need\" addtional stiffness but you would probably want it.
Caffeine
Re: Locost another option?
Postby Caffeine » Mon Jun 02, 2008 10:55 am
CONTI wrote:Redback Motorsport has alreay brought in a couple of MNR bike engine cars and have ordered their first MX5 single Donor chassis bases on a NB, but will be installing NC engine and 5sp for ADR compliance.
www.mnrltd.co.uk is the manufacture site. So keen I have already brought the Donor. Just waiting for them to complete and rego the demo!
:mrgreen:
Andrew
Looks quite nice...
Who else saw top gear on saturday?
it was the episode where they build a caterham while the stig drives one from london to try and beat them to the start line, classic!
Although live rear axle bleargh!
I've been looking more into the NC as a donor, and it all looks good, damaged NC's are ridiculously cheap importedfrom Japan (relative to damaged aussie models) except I may need to source an australian delivered engine to avoid emissions testing.
So I've been looking at focus / mazda3 wrecks, people have talked of picking up focus wrecks for ~$2500, and you don't care how much damage there is from the firewall back :)
So an NC wreck for most of the drivetrain / mechanicals, and a RWD converted focus or mazda3 engine for emissions (the sump etc is setup for FWD, and the compression is lower, so a bit of mix and match with the NC engine would be required...)
bjones
Postby bjones » Mon Jun 02, 2008 1:23 pm
Caffeine wrote: the sump etc is setup for FWD, and the compression is lower, so a bit of mix and match with the NC engine would be required...
We can always fix the compression ration just force more air in it insert :evil: laugh here
BJ
Playing with BOOST will smoke your tyres!!!
NO LONGER MINE sob sob
Caffeine
Postby Caffeine » Mon Jun 02, 2008 1:51 pm
BJ
Hehe, that would be interesting in a ~550kg car... :D
Have to make sure the traction control works!
Caffeine
Postby Caffeine » Mon Jun 02, 2008 2:02 pm
Hrmmm... the NR-A model looks interesting, only 5 gears (but you won't be getting ot the top of 5th much in a clubman anyway) but height adjustable bilsteins 8)
NR-A They seem to sell a bit cheaper than standard NC's too...
Caffeine
Re: Duratec donor engine
Postby Caffeine » Tue Jun 03, 2008 1:12 pm
CONTI wrote:There is some great info on www.ozclubbies.com.au on the use of Duratec engines from Focus' and 3's.
Yeah I've been reading that, very interesting stuff indeed :D
Caffeine
Postby Caffeine » Wed Jun 04, 2008 5:10 pm
I've been having a quick play with the weldment analysis functions in Solidworks, and I must say I'm impressed :D
Here's a simple cube shaped welded box, with 2in square mild steel tube, with a 500nm moment applied to one of the top corners, while the bottom of the box is fixed...
bigdog
King of the kennel
Postby bigdog » Wed Jun 04, 2008 10:09 pm
Yep, that looks like the rear end on BJ's after the first full throttle launch.... :P
bjones
Postby bjones » Fri Jun 06, 2008 1:29 am
bigdog wrote:Yep, that looks like the rear end on BJ's after the first full throttle launch.... :P
HEY you couldnt see the rear end through the rubber um I mean smoke. Besides the guru helps out with straightening it again
BJ
Caffeine
Postby Caffeine » Fri Jun 06, 2008 9:45 am
I've made a mock up of the duratec engine, based off some drawings available on the net. It's not absolutely accurate but it gives me a good idea how it will fit together and what will have to be moved...
Boost
Postby Boost » Sat Jun 07, 2008 10:15 am
Nice stuff Caffeine.
Change the units to mm instead of m. :mrgreen:
none as yet - looking for a white NA8
Juffa
Re: Designing a locost style Lotus 7 Replica
Postby Juffa » Wed Jun 30, 2010 4:40 pm
Never thought I would be bringing an old thread back to life, especially one on Lotus 7 replicas.
I have come across a damaged Westfield clubman. From photos and conversation with the owner it would seem that the chassis from the shuttle back needs to be replaced. The rear axle, body panels and fuel tank would also need to be replaced. Otherwise the car seems to be in reasonable condition. It has a 4AGE 16 valve engine, Toyota T50 G/Box, Ford Escort diff , Carbon fibre dash , bonnett bulge & front guards , twin master cyls with balance bar , braided brake hoses , a fuel surge tank set up , CAMS licensed roll bar , front anti roll bar & AVO shocks. The car was built and used as a track car only, it has never been registerd and I assume therefore has not needed to be certified for ADR purposes. The owner is asking $4,500 as is. I am thinking of buying the car and then either repairing the damage, or remove everything from the chassis and build a new 'locost' chassis, while putting all of the running gear on the new chassis. My goal is to have a road registered Lotus 7 replica, which I assume would be easier with a new chassis, rather than trying to repair an existing one?
So, does it make sense to pay $4,500 for a car where I may have to throw away the chassis and start again? A quck calculation suggests that the replacement value of the running gear, fibreglass panels and other parts would be close to the asking price (feel free to correct me if I am wrong). Can anyone suggest what a 'locost' chassis might cost, assuming that I aquire the metal and do the build?
Note: Like a lot of things this may turn out to be a pipe dream, and based on the cost may never happen, but one is allowed to dream :)
J.
Caffeine
Postby Caffeine » Thu Jul 01, 2010 10:18 am
Juffa wrote:It has a 4AGE 16 valve engine,
Not sure if you are allowed to do 'new build' clubmans with the 4AGE, I could be wrong though...
Postby bruce » Thu Jul 01, 2010 10:38 am
Getting it road registered sounds like a world of pain. It's never been rego'd so it would have to be ICV'd. Problem is, who will do that? Locost will sell you a chassis but they won't sell you Compliance (they would have to supply the whole kit to ensure compliance). To individually ICV it is not going to happen.
Juffa
Postby Juffa » Thu Jul 01, 2010 11:54 am
Thanks Caff. Is that due to the latest emmision requirements and the age of the 4AGE engine? If so, I believe that Arrow Clubmans (Aust company) have had the 4AGE ECU complied for the latest requirements. I was going to paste a link from the OZ Clubbies website, but having problems with their search engine today.
J.
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
