NC swaybars queries
NC swaybars queries
I'm trying to research replacement front and rear sways for my 2007 NC.
I've sussed out some adjustable Whitelines, but need to know the cars current standard front and rear measurements in order to see how much stiffer the gain will be. What are they at the front and rear measurements in mm?
Also, very keen to hear from anyone who has front + rear Whitelines in their 2006+ NC, and opinions on handling after having them fitted.
- Garry
I installed some hollow bars from MX5PartsUK onto Kuntry Kuzzins NC. He was pretty happy with the outcome. I think there's a post about them on the forum somewhere. The new bars were heaps lighter than the factory bars and were beautifully made.
- Charlie Brown
Stock bars are 21.1mm front and 12mm rear
Whiteline adjustables are 24mm front and 16mm rear
Set on softest settings (ie same arm length as the standard bar) the fronts are 71% stiffer and the rears 215%
When I spoke to Whiteline they couldn’t tell me how much stiffer the bars were on the other adjustable positions.
On the road I’m running the soft (71% stiffer) position on the front and the middle position on the rears.
Thanks Charlie Brown
Would you say these two would reduce body roll significantly?
Charlie Brown wrote:Stock bars are 21.1mm front and 12mm rear
- Charlie Brown
I had custom sways made for my car. No problems with the front but the back was 18mm and snapped the bolts which were welded to the subframe and bent the brackets. Ended up drilling out the bolts and putting in high tensile ones with polyurethane bushes.
Big difference in the way the car handless.
Depending on how thick you want the cars, you should also consider changing the rear bolts.
The car is a tad louder when going over speed humps though.
- MxJadeMonkey
I had those bars made for him, I also fitted the rear one, The bolt snapped due to my over tightening, not that the bar was to big, I have done a few NC's now with 16mm and 18mm rear bars, I have since sorted out the issue with him.
lesson learnt for me about rear NC sway bolts.
car should handle great now though after being repaired.
1991 NA6 Velocity Blue (Ford Colour)
MxJadeMonkey wrote:I had those bars made for him, I also fitted the rear one, The bolt snapped due to my over tightening, not that the bar was to big, I have done a few NC's now with 16mm and 18mm rear bars, I have since sorted out the issue with him.
It's a her. The guy that was there was just the bf. =p
Users browsing this forum: No registered users and 368 guests
