anyway back to it
pod cover is done, hopefully it's legal (or at least more so that it was before)
SM wrote:Well i didn't know that before
anyway back to it
marcusus wrote:Do those screws actually hold much down? Those particular ones don't really have much thread on them if they're similar to ones in the carpet etc.
How about the edges of the cover? Has it all been smoothed off, or is a tad razoresque at the moment?
Mr Morlock wrote:alex that looks a nice solution- alu is a good product. Perhaps a thought might be to get a small u section extrusion in rubber or plastic run it around the edge fix with glue with join where it cannot be seen. Clarks seem to have quite a good range of extrusions. The blk screws look just right- the small details make a difference.
SM wrote:they are similar to what is used to hold down trim panels, so they expand as the "screw" is pushed in/screwed down and easy to remove when the pod needs cleaning/replacement as well
I didn't think about it very long before just using these, if you have a better solution let me know
edges not razor sharp as they have been sanded after cutting
Alex wrote:Not much has changed on the car, got a MX5Plus number plate mount though (thanks connico)
marcusus wrote:Alex wrote:Not much has changed on the car, got a MX5Plus number plate mount though (thanks connico)
I thought you'd already gotten one of those, but you didn't fit it because your dad kept stepping on it to break it off or something?
sliq wrote:i think he's getting an se
