Low Clearance Car Ramps
- sliq
Hi Guys,
This may be a stupid question... but..
Is there a certain brand of car ramps that has enough clearance for your mx5 to get up on without damaging/scratching the front bar? I've got a set of car ramps which I tried getting my car up on and it has left massive scratches at the bottom of the bar
There's some work I need to do in the engine bay i.e. replace radiator and do some drilling from underneath.
I don't have any jackstands btw.
Or does anyone have clever ideas on hoisting a car up?
- MasterZ
- Vehicle: NA6 - Turbo
could you get 2 pieces of wood and sorta make it less of a slope by putting the wood from the ground to the ramp if you know what i mean?
i drew a diagram in paint lol
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
- sliq
- MxJadeMonkey
I Have an NA 30mm lower than standard and have a set of ramps that i just drive straight up onto, they are the same height as all the others i have seen, I have also used a mates shitty super cheep ones and they were fine too, and that was on wet grass! how low is your car man?
1991 NA6 Velocity Blue (Ford Colour)
- sliq
- Steampunk
- lowmiata
The NB8B probably has a smaller entry angle hence you guys are comparing apples to oranges
some sujestions
-as per how it was detailed aboveexcept don't take the timber all the way to the top
(just pump it high enough to clear and get to the ramps then go up them)
-don't use bricks under the timber, get a decent 10x2 sleeper
-if there is a gutter close by you could might be able to utilise it by dropping the back wheels into it to raise the front
-if your trying to attack them on an angle(viewed from above) ie on your semi circle drive way you will always have problems try and straighten out the angle maybe?
-never sucumb to doing it on grass!
there are lots of ways of doing it lots can be dangerous too
get yourself a spotter so that you dont have to keep stopping and checking as you car will go up and down when you get out of it!
if its got a hard top remove it take what ever you can out to raise the height!
your car will go down approx 8mm from and empty tank to a full one!
I don't bother with ramps obviously
FWIW even a standard BA xr6 doesn't go up normal car ramps without a bit of thinking!
Think outside the square and you will get there!
some sujestions
EVI15 1998 to 2008
- Matty
- sliq
Matty wrote:US guys swear by Rhino ramps, which I have only ever seen once (at Autobarn, for a lot of money). Plastic moulded pieces, lower than most with a very shallow approach angle.
yeah, i was about to head down to autobarn..
how much were they, the last time you saw them matty?
a few guys on clubroadster use them..
Sliq- I think lowmiata is pretty much on the money - he has done this before- spotter necessary in case you drive off the end of the ramp. If you can get a standard ramp suitable such as the rhino mentioned that would be good- check the approach angle and length. . Personally I think if you are wanting to use a ramp another option is to get the local welding shop to make you a \"ladder \" which you can hook over the slats so that the entry angle is reduced- I'm thinking sound engineering .
The other option maybe better is good floor jack to raise the vehicle, support with stands, chock wheels- which is what I do ( NB) The floor jack and stands last you for years- or borrow from a mate.
- sliq
- Matty
- bigdog
- King of the kennel
sliq wrote:does anyone here use jackstands? i'm a bit reluctant to buy a pair because it looks like the car mite tilt and fall when they're on the jack stands
Have used stands for years without incident. The trick is always have two forms of support under the area you are working on - ie jack plus axle stands, so that if perchance one gives way the other will support the car.
- fattima
I use stands all the time, I have for years and never had a problem. Put them under the jacking points and you should be fine.
Users browsing this forum: No registered users and 190 guests
