I thought Tempe Tyres only did big chrome bling rims?? Which are definitely not lightweight.
Maybe I'm getting them mistaken with another crowd?
Lightweight 15x7 rims?
Adam_NAclubman wrote:I've got 15x7 +17 Buddyclub P1's, theyre six and a half kilos but way cheaper than most of your other options
mmm, which P1's though? cuz the SF's are cast wheels where as the QF are forged ones. Forged ones are the exxy and very light ones at 4.6kg for 15x7
- CapitalF
- Vehicle: NA6 - Turbo
Aaaamazing - Ive been doing same research over the last few weeks.
From the Goodwin web site re a used set of Enkei RFP1's: \"Fits all 1990 through 2000 year Miatas...does not fit aftermarket or the factory big brakes which became OPTIONAL in 2001 and standard in 2003\"
...so although I'd nearly settled on these amazing wheels as an upgrade path I now will revert to the 949 product that will fit the larger factory 1.8 size brakes.
Rascal - note also a fellow who races Prod Sports in Bris is bringing in 30 of these 949 wheels in 15x8 in the next 5-6 weeks. Not my preference but may suit you.
Edit - Nb that 949 have a template you can print /use to check your clearance well down this page: http://www.949racing.com/index.asp?PageAction=Custom&ID=1
Peter
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
Yeah, I used the 949 clearance template stuck to cardboard, to check but it is soooo close that I can angle the template 1mm in & out and it fits or doesnt, so really need an actual wheel to be sure...
Can order two only to make sure they fit (they'll definitely fit on the back..) but then I'll have to wait till aug-sep for the first two wheels and then if they fit probably another 6weeks or so for the other two, meaning possibly Dec before I get a full set of rims I can use... or if they don't fit I end up with mismatched rims f to r.
- CapitalF
rascal wrote:Adam,
If you don't mind me asking, how much did you pay for your P1s and where did you get them?
Bought them off a forum. SF's
$500pp if you want them
Users browsing this forum: Google [Bot] and 235 guests
