The RX7 looks very composed. Better driving or sway bars needed?
OOPS posted as new topic
TCR wrote:What suspension do you have?
Paul.
bobg wrote:TCR wrote:What suspension do you have?
Paul.
I have Tein Super Streets.
I was wondering if the photogapher had caught me in a position where this attitude may be normal?
I am have only recently fiited the Teins, so did not want to complicate with adjustable sway bars just yet.
bobg wrote:After studying all the phots of turn 2 at EC, I think the attitude is normal. The suspension is not race spec as the RX7 and this photo may be on the warm up lap, I am usually weaving to get some warmth in the tyres.
The car is a daily driver and the specs of the TEIN SS Coilovers are as follows:-
FRONT
SPRING RATE / PART No. Replacement Availability
kgf/mm lbs/in Part # Max/Min(kgf/mm-lbs/in)
7 390 SA070-01150 +2.0 / +110.0 to -2.0 / -110.0
REAR
6 340 SA060-01150 +2.0 / +110.0 to -1.0 / -60.0
Which seems heavier than Robert's spring rate, but will need to ckeck the part No's on my kit
Anyway thanks for the advice, I think I will not race out and spend more money.
CT wrote:Those are the flex spring rates - not the SS rates - used to be around 283/200 I think. Did you spec them with higher spring rates?? And yes, you need heavier sway bars.bobg wrote:After studying all the phots of turn 2 at EC, I think the attitude is normal. The suspension is not race spec as the RX7 and this photo may be on the warm up lap, I am usually weaving to get some warmth in the tyres.
FRONT
REAR
bobg wrote: Have you any advice on sway bar brand?
Users browsing this forum: Bing [Bot] and 5 guests
