14\" tyre question
SuperMazdaKart
Postby SuperMazdaKart » Tue May 13, 2008 6:40 pm
whats the cost?
chrislevingston
Postby chrislevingston » Tue May 13, 2008 7:35 pm
$130 each plus $2.50 tyre disposal fee.
That's fitted, balanced and aligned.
I will take along the report that The Mag Wheel Centre gave me after they aligned them, as they appear to be just right for what driving I do.
Changed the Eibachs and Bilsteins to Kings and Konis since then, but guess that should not affect things?
Chris
1990 "TOY MX5" - Red, of course!
Kings, Konis, LSD, Genie system, grille, Voodoo knob, braces, 14 degrees ATDC, woodgrain dash,style bars and lots of work making the rubber bands go around faster.
chrislevingston
Postby chrislevingston » Fri May 16, 2008 6:18 pm
Just fitted, and rain bucketing down!
Excellent service.
Thanks for the advice, guys.
nath
Postby nath » Tue May 20, 2008 12:33 am
How do you find them Chris?
chrislevingston
Postby chrislevingston » Tue May 20, 2008 1:15 pm
Excellent, and better than the A539s in the wet.
They seem a little gripper in the dry, as well.
(BTW, I stuffed up on the price - the wheel alignment was $60).
BTW, I took in my wheel alignment report from when I had them done last, and they did them exactly as I asked, so that's a thumbs-up for Bob Jane.
Chris
mr_rotary
Postby mr_rotary » Mon May 26, 2008 4:54 pm
Planning to get some GIII's within 2 weeks. I have noticed some used a 185/60/14 (std) and some use the wider 195. Rolling diameter is slightly larger for the 195. What's some of your comments on going wider? Any difference in appearance (and not look like a 4WD tyre!)?
Postby manga_blue » Mon May 26, 2008 8:16 pm
185/60x14 is a better fit and give better response and turn-in. The 195s get a bit rolly.
