Whining Noise on start-up
- RaYmO
Hi Guys,
Just noticed today that when I start the engine when cold, there is a distinct whining noise that lasts for about 10 seconds before it goes away completely (and no it's not coming from the passenger)...
Anyone experienced something like this before?
- SuperMazdaKart
- JBT
- StanTheMan
Both my waterpumps made a metalick sounding noise .....for about 12mths before they failed. It was more a sort of a constant noise but it would be there always.....not dissapaer.... until the waterpump got replaced
I'd ceratinly be checking in JBT's & sprangas direction.
- RaYmO
Thanks for your input guys
I'll give the belts a run through tonight
The weird thing is that this noise is only present on cold startup - When I restart the car when the engine is warm there is no noise
Also, if it were the belts... wouldn't the noise be constant (ie not go away after 10 or so seconds?)
I think the culprit may be the AC condenser as that has always been noisy since the last regassing.
- RaYmO
OK
Managed to do a quick check this morning.
I put the key in the ignition and turned it so the radio was on (without starting the engine)
The noise was LOUD as I had my bonnet up. Was following the noise and it is coming from the Fan in the Radiator. It sounds like the fan is rubbing against the metal...
Is it possible that the fan is somehow loose and needs to be tightened up?
RaYmO wrote:OK
Was the engine still cold at this time? The fan should not spin unless triggered when the coolant temp reaches a certain level. Check that the shroud around the fan is not warped/bent. With the key removed check the fan for excessive movement. Obviously spinning is fine, but it should not have too much wobble.
J
- StanTheMan
