My 1994 clubamn
silverback2002
My 1994 clubamn
Postby silverback2002 » Mon May 19, 2008 12:05 am
This is my 1994 clubman. I bought it in very very bad condition and have rebuilt it from ground up.
Totally resprayed in and out, cleaned up the engine and drive line.
Made some engine mods but now back to stock standard all over in and out. Its in shown room condition.
Will be planning to sell in the near future.
Boags
Postby Boags » Mon May 19, 2008 12:10 am
:shock: :shock: :shock:
Schweeeeeeeet.
How much are you looking for? Mint NA8 Turbos aren't cheap... 8)
silverback2002
my na8 clubman SOLD!!
Postby silverback2002 » Mon May 19, 2008 12:22 am
Well I have sold off all my turbo bits so she is back to stock NA8 Clubman No turbo.
Might want it for next summer we will see.
+ I have mazda A/C installed too.
If I get a good enought offer I may consider selling before summer.
Last edited by silverback2002 on Thu Sep 18, 2008 7:15 pm, edited 1 time in total.
Postby sliq » Mon May 19, 2008 2:02 am
nice cute lil kitten.. good job restoring it
Hot Rodders
Postby Hot Rodders » Mon May 19, 2008 11:12 am
nice job! Any before restoation picis?
Evo, Its not a Dirty Word! Good As Gold.
President Bendigo Gliding Club
www.bendigogliding.org.au
Jimmy
Postby Jimmy » Mon May 19, 2008 11:16 am
Oooooh aint she a QT (number plate)
Very nice, put up some \"before\" shots :P
silverback2002
clubman
Postby silverback2002 » Mon May 19, 2008 6:49 pm
Funny enough I never took any. Maybe I was too embarrassed.
When I picked it up from Hoppers crossing in Vic it was like this:
The paint was a tan colour
four flat bald tyres no brake pad. (worn out)
Rusted out pillars must of had a screen leak that was never fixed
roof ripped and been constantly rained in.
Cat sh*t and what seemed snail bait or kitty litter every where.
Cob webs inside all over.
No oil in the engine tip some in and it came straight out the bottom.
Rear callipers were locked on.
Rear main dripped.
Interior had toys glued to the dash board
Windows didn’t work
Shift boots (Both) ripped and leaking oil.
Had slotted rotors on but needed a grind as the peddle shuddered
Drivers seatbelt didn’t return back
CAS O-Ring
The body had approx ten dimples on every panel.
Prior to rolling it into the panel shop I had it under various lights to get the right lighting to see all the dents. I marked each with a red highlighter .
Looked like the car caught a disease.
May panel beater a friend did the best job spayed in Glasurit automotive paint.
No bog in the car, all dents pulled out and panels high filled. All rust cut out and panels welded ( Windscreen)
I wont tell you the price because It will make you all cry.
The down side is I didn’t have my car for almost 1 year as it was a \"On the side job\".
I think It cost him more then it did me.
Now its like new no rattles nothing squeaks drives well.
I then turbo charged it, the wife wouldnt drive it anymore so now it back to stock.
Now a baby to throw a spanner in the works could see it with a new owner.
I'll try hold onto it for a bit longer.
Dan
meanmx
Postby meanmx » Mon May 19, 2008 9:58 pm
That is immaculate and something to aspire to. Fastfreddy told me your car was superb but the photos truly bought it home. Well done
Ben
2014 VW Mk7 Golf R
Postby Hammer » Tue May 20, 2008 1:02 am
Another nice classy clean ride.
silverback2002, I noticed from your pic that you have a turbo blanket installed? Does it really make a different in reducing the under-bonnet temps? What are your thoughts on this - Pros & Cons?
corners
Vehicle: ND - Supercharged
Postby corners » Tue May 20, 2008 2:34 pm
what a mint example of of an Mx5 a clubman at that!!!
Well done!!!
Lucky_Luke
Postby Lucky_Luke » Tue May 20, 2008 4:23 pm
Yes. Yes it does look rather tidy!!
and thanks for the exhaust Dan!! :D My dad loves it!!
Sounds soooo nice!
L.
silverback2002
Track dog racing blanket
Postby silverback2002 » Tue May 20, 2008 7:40 pm
The blanket is a track dog racing one.
I had it on my NA extractors prior to turbo .
It worked 70% better then any baffles or heat plates BUT my stainless steel manifold which was coated in high temp black still managed to melt the exterior.
You must get a turbo heat rated blanket. They are not cheap.
It cut down all the radiating heat that come off my manifold.
The turbo manifold I had would get that hot if you even touched it for approx half a second it would blister you badly. So the blanket didn’t do too bad under those conditions.
It was a thick blanket padded with heat material and layered with the foil like material on the exterior. you could bend it to form any shape and it would stay in that form.
Best thing for headers because it will not rust them over time.
Dan
garettb16
Postby garettb16 » Wed May 21, 2008 8:36 pm
very impressive mate. and great dyno results!!
huge power.
AB7
Postby AB7 » Thu May 22, 2008 11:16 am
Very nice...well done.
Who did your turbo work?
Looks very well made.
silverback2002
Turbo build
Postby silverback2002 » Thu May 22, 2008 9:13 pm
I did all the work myself.
Handy with the tools.
Only cut myself a few times and needed stiches.
Those dam intercooler pipes are thick stainless steel and almost impossible to cut with a hack saw.
Users browsing this forum: No registered users and 26 guests
