After measuring the OEM height I have noticed that passenger side sits about 5-6mm lower then the drivers side, putting mwah in the drivers seat makes D & P height about equal.
Is kerb weight considered when setting P & D coilover height? If so, would you apply the same principle when setting the height with aftermarket coilovers.
P = passenger side
D = Driver's side
Kerb weight in relation to coilover height
- blackster
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- PASHN8
Did you buy coilovers Phil? If so, what did you get?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- blackster
wun911 wrote:Seeming you have coilovers you can cornerweight the car.
Corner weighting (if i can use that word) as i undestand it attempts to provide even weight distrubtion to stop the car from wedging or reverse wedging. The process of going about it seems a bit of an overkill for a street car.
I am wondering if whether mazda deliberatly from factory adopted corner weight principles, as un even height; which is noted affects weight on that corner. Perhaps the placement of the battery in the right rear also serves a purpose other then being placed there because of a lack space.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Charlie Brown
- blackster
Charlie Brown wrote:You have a very rare car there Blackster. 99% of vehicles would be lower on the drivers side than the passengers
Care to share the reason why? Apart from having a driver that surpasses "kerb weight"
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- Charlie Brown
blackster wrote:Charlie Brown wrote:You have a very rare car there Blackster. 99% of vehicles would be lower on the drivers side than the passengers
Yep, overtime that great lump of dead weight located amidships of the car (the driver) causes the suspension to settle/droop/drop/sag on the driver’s side. Race around to a few cars with a tape measure and see what I mean.
I'm NOT saying there's more unladen weight on the drivers side, just that most vehicle without the driver are down on the drivers side. A lot of people swap sides with their springs when replacing their shocks in an attempt to have the car settle evenly over time.
S’pose if you think about it, it would mean that the car is level when the camber of the road is taken into consideration.
PS Out of the factory mine was 5mm lower on the right rear than the left but the fronts were within 1mm.
- Garry
Users browsing this forum: No registered users and 206 guests
