Anyone one knows ?? Ticking noise from the clutch !!!
maxmx5
Postby maxmx5 » Fri May 09, 2008 11:35 am
Hi Guys,
I got a high pitch ticking noise from the clutch, it happens when the car is on idle, and as soon as you tap the clutch the noise goes away, all it need is a very gentle tap or put your foot on the clutch and the noise goes away !!
any one who has this issue in the past please advise ..
thank you very much :D
Postby Mr Morlock » Fri May 09, 2008 11:53 am
Probably thrust race- take it to clutch specialist for diagnosis.
maxmx5
Postby maxmx5 » Fri May 09, 2008 12:00 pm
Mr Morlock wrote:Probably thrust race- take it to clutch specialist for diagnosis.
I spoke to a mechanic and he said that he need to pull the clutch apart and have a look.,... dam..
JBT
Postby JBT » Fri May 09, 2008 12:15 pm
Check that there is a small amount of grease on the end of the slave cylinder plunger where it contacts the clutch release lever.
Garry
Postby Garry » Fri May 09, 2008 12:23 pm
What JBT said. Much cheaper than a clutch overhaul.
silvermiata
Postby silvermiata » Fri May 09, 2008 12:35 pm
JBT
Posted: Thu May 08, 2008 1:15 pm Post subject:
x 2
maxmx5
Ticking noise,
Postby maxmx5 » Fri May 09, 2008 12:37 pm
I am going to give it a try to see how it goes, thanks a lot guys...
:D
