ASE05 wrote:Just went up the road to Bribie Island to sort some stuff out and on the way up she started to get a lil' harder to get into gear.....hmmmm, somethings not right me thinks![]()
By the time we get to Bribie, I can hardly change gears at all w/out matching revs to get it into gear. Yep, something really aint right here. The last roundabout before the BP servo we had to pull into I couldn't get her to stop moving even with the clutch all the way in![]()
Now with the clutch out, she squeels like a cut pig and goes almost quiet with the clutch all the way in, not really happy.
hmm, slave cylinder maybe?? mine went on saturday which made the hour drive back from the Butterfly install day alot more interesting than normal, sounds just like what I was experiencing except for the squealing
hard to get into gears, most noticable when trying to engage 1st after stopping at a set of lights, then it just got worse and worse
I managed to drive mine for so long by pumping the clutch alot to get some pressure to get into 1st then basically flat shifting into the next gear so ended up in 2nd the whole way to mania
