The blue beast is very much a garage queen these days and it will be coming back into very occasional use soon but like once a month. So what are people using and can you use to keep the battery healthy between runs.
I am talking about something thats other half friendly otherwise i'd just disconnect it.
thanks
Battery saver / Trickle chargers
Battery saver
I have a 1968 P1800 which I use very infrequently. I have a marine grade battery and keep it on a trickle charger that has a full charge cut-out. Has worked a treat for the past 4 years with the one battery.
- Steampunk
Don't forget that very low usage will not just cause an issue with the battery, but water-pump seals and other bits will suffer from lack of lubrication.
Just do what I do and go for a leisurely 20-30 minute drive around the neighbourhood once a week.
Or the least you can do is let it sit at idle for 10-15 minutes once a week.
Just my little $0.02
- Boyracer
- MX-5 Encyclopedia
- Hammer
Users browsing this forum: Google [Bot] and 90 guests
