NB8A vs NB8B
Which one would you buy?
NB8A 30,000kms A few scratches in paint
6
16%
NB8B 80,000kms good paint
31
84%
Total votes: 37
wun911
Postby wun911 » Wed May 07, 2008 4:29 pm
I'm kinda short I understand if your tall and you want a roll bar then ok.
As for 6spd im just lazy
every ounce counts
blehbear
Postby blehbear » Wed May 07, 2008 4:44 pm
The passenger seat of the 8A tends to rattle when there is no passenger too.
Boags
Postby Boags » Wed May 07, 2008 4:54 pm
PUR157 wrote:Back on topic
If no one offers Boags, I would love to help out!
Not too sure I would be the one with the best expertise in this area so just keep me in mind as a last resort :D
No one else has offered. :frown:
Any NB owners feel like taking a car for a drive? Just look for unusual paint damage (like scratches rather than stone chips); and wear on the interior.
Other things to keep an eye out for will be strange noises or vibrations. AND RATTLES!! I HATE RATTLES! :roll: :lol:
I will obviously inspect and drive any car before I buy it, so don't be scared of recommending the wrong car or anything.
PUR157; if you think you can handle this (I think you could) then I'm happy to send the contact details to you. :D
Thanks,
Boags
Postby manga_blue » Wed May 07, 2008 6:54 pm
I'll put my hand up for any mountain testing required on a Melbourne one.
Hellmun
Postby Hellmun » Wed May 07, 2008 7:03 pm
Me and Andrew have dríven each others cars a few times so we've got a little experience directly comparing the 8a to 8B. Plus building two stock standard cars into track-dogs. Though you never said what you were getting it for specifically.
As a daily driver I'd take the NB8B, the seats were much nicer, they hug you more. The White face red illuminated Dash looks nice, the centre console is more usable, standard 4 speaker system. You get better brakes with ABS, Strut tower brace, mid-section brace plus all the cosmetic stuff.
The Sports brake package also does fit under 15\" wheels, just not certain ones like the Enkei RPF's. Additionally you get a compression bump and main bearing support plate in the 8B.
It's when you get to the track it gets more complicated. The only setbacks for not going the NB8B are that when you swap a 4.1 diff onto the back of the 6 speed the speedo will go out. That however is cheaper than putting a 6 speed box in to replace a 5 speed(speedo is sent from the gearbox). The Non-ABS aspect is better at the limit on the track, if you get a wheel airborn you won't get brakes as the ABS keeps letting go. You do however get easier cam options (the NB8B has one cam on offer from maruha). Easier to make power out of the NB8A and you can put everything from the NB8B onto it.
Given the choice to do over... I'd still have to think about it a lot, I know upgrading to NB8B brakes can involve a bunch of fiddling to get the bias right but cams seem even more fiddly with my NB8B. You could direct upgrade to an SE 6 speed box too and get stronger internals which is a boon from the NB8A.
AB7
Postby AB7 » Wed May 07, 2008 8:09 pm
NB8B for me...its simply a better car.
Garry wrote:Be patient and keep looking for that elusive NB8B with good paint and low km for the right price.
Thats right, I waited for 3 months to find my car. You'll be surprised there are quite a few very low K's example around. They do pop up now and then, you just got to be quick when you see one. When I bought mine it had only 12KM and at the same time, there was another car with 13KM advertised on MX5 Club Sydney.
AJ
Postby AJ » Wed May 07, 2008 8:21 pm
wun911 wrote:I'm kinda short I understand if your tall and you want a roll bar then ok.
learn how to skip gears then :? ........the 6 speeder in the NC is pure joy as far as i'm concerned, & i can't see why it'd be any different in the NB..........on the twisty mountain roads, you're never caught in 2 minds about which gear to use in a 6 spd with the closer ratios.................& if i'm feeling lazy on the open freeway..........coming out of the tolls for instance, i'll use 3rd & 4th to accelerate up to the speed limit & then just bypass 5th & go straight for 6th....................or, you can dodge 3rd & go from 2nd into 4th comfortably if you rev it out in 2nd, there is no rule that says you have to use every gear :mrgreen:
XMX5 Rogues
zombie
Postby zombie » Wed May 07, 2008 9:34 pm
I agree, close ratio 6speed is pure joy, although I can't remember the last time I used 5th :P
I tend to either go 1st->2nd->6th or 1st->2nd->3rd->6th :)
40km/h in first, 80km/h in 2nd, 120km/h in 3rd.
I'm sure once I start tracking the car I'll be using 4th and 5th more :mrgreen:
As AJ says, just because you have 6 gears doesn't mean you have to use them all every time, but it's nice to know no matter what speed I'm doing, there's a gear I can drop to that'll give me revs in the power band.
Previous MX-5s:
Innocent Blue NB8A 10th Anniversary Edition
Stormy Blue NC2 Cosworth Edition
stevesports
Postby stevesports » Thu May 08, 2008 12:01 am
zombie, sounds like you hit 5000-5500 in each gear by the way you drive.
Fatty
Postby Fatty » Thu May 08, 2008 12:09 am
stevesports wrote:zombie, sounds like you hit 5000-5500 in each gear by the way you drive.
is there any other way to drive an mx5? :?
i usually shift at about 6800rpm :shock: when i'm in "spirited driving" mode
bigdog
King of the kennel
Postby bigdog » Thu May 08, 2008 12:37 am
i usually shift at about 8600rpm :shock: when i'm in "casual driving" mode
Fixed :P
And Boagsy, I would have been first to raise my hand to do some test driving for you, but I'm off overseas again this weekend. If you're still looking in a week's time I'm happy to help. BTW, note STM's subtle comment - this comes from the driver of a very well sorted NA with no axe to grind. Nuff said. :D
Alex
Postby Alex » Thu May 08, 2008 12:44 am
I skip gears even in the 5 speed so i don't know why you 6 speed people are complaining
mostly at roundabouts, change to 2nd before entering, WOT through then change straight to 4th once the speed limit has been reached on the other side :D
PUR157
Postby PUR157 » Thu May 08, 2008 2:09 am
Boags'MX5 wrote:PUR157; if you think you can handle this (I think you could) then I'm happy to send the contact details to you. :D
Haha... Alright then, I'll try my best!
Oneness of Man and Machine
AJ
Postby AJ » Thu May 08, 2008 5:41 am
6800 is the optimum rpm to change up in the NC, i've found anyway 8)
XMX5 Rogues
Postby Okibi » Thu May 08, 2008 9:40 am
Everythings gotta be about NCs doesn't it Clive :P
